1 members (Snowman51), 94 guests, and 12 robots.
Topics128,014
Posts1,055,324
Members48,419
#1088619 03/01/2015 1:57 AM
I have a 52 3100 that had an early 350 dropped in 2 or 3 owners back. There is a spark plug that is located behind the steering box. I can't get a socket on it. Does anyone have an idea for changing it?
David
1952 Chevy 3100
5 Online: Content
How did you shoehorn the 350 in with the steering box in place?
Carl
is there room to get a "boxed end" wrench on it coming up to it from the bottom.
Good idea on the box end. I don't know if I can reach it from the bottom. I'll try tomorrow.
A previous owner dropped the motor in.There's almost no room. It has rams horn exhaust manifolds.
1952 Chevy 3100
You might have to loosen the motor mounts and jack the engine up a little. Accell makes a short-insulator spark plug for use with headers that might be an option if you can get them in the right heat range.
Achipmunk, after 2 hours and a lot of grinding on an old wrench I go the plug changed. Thanks for the tip.
Also, I got all my turn signals and brake lights working today. Thanks to everyone here for the tips.
1952 Chevy 3100
