0 members (),
39
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2015 Posts: 34 | I have a 52 3100 that had an early 350 dropped in 2 or 3 owners back. There is a spark plug that is located behind the steering box. I can't get a socket on it. Does anyone have an idea for changing it? David
1952 Chevy 3100
| | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | How did you shoehorn the 350 in with the steering box in place? Carl
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | is there room to get a "boxed end" wrench on it coming up to it from the bottom. | | | | | Joined: Jan 2015 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2015 Posts: 34 | Good idea on the box end. I don't know if I can reach it from the bottom. I'll try tomorrow. A previous owner dropped the motor in.There's almost no room. It has rams horn exhaust manifolds.
1952 Chevy 3100
| | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | You might have to loosen the motor mounts and jack the engine up a little. Accell makes a short-insulator spark plug for use with headers that might be an option if you can get them in the right heat range. Jerry
| | | | | Joined: Jan 2015 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2015 Posts: 34 | Achipmunk, after 2 hours and a lot of grinding on an old wrench I go the plug changed. Thanks for the tip. Also, I got all my turn signals and brake lights working today. Thanks to everyone here for the tips.
1952 Chevy 3100
