| | | Forums66 Topics128,179 Posts1,057,157 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | I've made the difficult decision (for me) to use the more modern copper-nickle brake lines on our 1950 fire truck restoration, due to their superior corrosion resistance and forming characteristics. However, I'm wondering if anyone is concerned with galvanic corrosion between the copper-nickel brake lines & the steel clips used to hold them? I'm no chemist or engineer, but it seems to raise an issue that didn't exist with steel lines and steel clips. Much ado about nothing? -Mike Stemmler | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | There is no problem with regular steel and Cu-Ni.
The problem comes between Stainless, aluminum and brass. | | | | | Joined: Nov 2010 Posts: 123 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 123 | I always thought copper-nickle was best used for fuel line application, or anything with a "single flare to brass." I could be wrong but my guess is that copper would fatigue more under brake line pressure and higher torqued connections with steel. | | | | | Joined: Dec 2006 Posts: 206 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 206 | The Ni-cop lines are made for brake systems and have been used in northern Europe for decades to prevent corrosion. Its just starting to be the line to use here due to the extra cost. It flares better, easier to form and while it cost s little more you have much less waste while flaring. I use it on ever build I do but I don't mix it with systems that also have steel. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Calling it "copper-nickel" might be a little misleading. The alloy used is actually copper-nickel-iron. It takes double flares just fine, as Dave states, much easier than paint steel.
Bill Burmeister | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ..and if your worried about the clips that hold the lines use the "coated" clips. You know, the ones with the rubber on them. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I've been using Kunifer brake line here for more years than I care to remember. In fact my truck is the first vehicle i've ever owned that actually used steel. I used a 'universal' steel brake line kit sourced from TCI in the USA for simplicity,it came with all the brass fittings,brake light switch and aluminium chassis clips.
I actually ran out of steel line and used Cu for the rest and have had no corrosion issues in any form despite the fact the truck is driven in all weathers including salted winter roads.
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jan 2002 Posts: 2,844 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,844 | I just remembered that I have a whole role of Cu line. Maybe I should use some on the truck.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | cmayna, I did mine with the NiCop. I too had a roll in the garage. It's still there - somewhere! Couldn't find it so bought another. There is just too much stuff in my tiny garage with the truck blown apart for paint and improvements to find it.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | So it sounds like I can find better things to worry about than corrosion with the clips or fittings.
Or, put another way, when THAT is the biggest problem I have with this truck, I will be in a very good spot!
Thanks for the input. FWIW, the lines have been very easy to work with so far, and look good. My OCD kicks in about the straight pieces not being totally "straight" like fresh lengths of steel, but I think I can deal with it!
-Michael | | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | There's a sneaky little trick to straighten rolled-up tubing. Clamp one end of the roll in a vise, roll it out, and use a pair of vise grips, a come-along, and something rigid like the bumper of a car to put just a little stretch on the line. Don't overdo it, as you'll reduce the diameter of the line if you go too far, but it comes out arrow-straight with just an inch or two of stretch over the length of a 50-foot roll! Cut, bend, and flare the straightened line as required! Jerry
| | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | Thanks, Jerry! That's exactly what my mechanic did - I'd not seen that trick. Works well! Got the line as straight as the original - including a bend in the original that had no purpose, far as we can tell. Oh well - flaws and all!
-Michael | | |
