7 members (NJC, Gray_Ghost, GMCJammer51, Greg_H, 50Chevy3100, 1955 1 Series, 1 invisible),
74
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2015 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 33 | Hi to all, I am a new member to your group. I have a 57 - 3100 with a 235-6 cylinder. I have recently put a Drum to disc conversion and now I am lookin. To upgrade to powersteering from manual. My concern is that there are many options out there, CPP has a upgrade that is the original type power unit and of course there are other more modern types setups. Does anyone have an opinion on what works best. Of course the other issue is the bracket for the power steering pump. Any input will be appreciated. Thanks Kevin
Thanks, keep truckin!
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Welcome to the Stovebolt  I'm building a 56 3100 and I went with the Total Cost Involved power rack and pinion for the straight axle. I'm not on the road yet so I really can't tell you how it preforms, but I like the way it looks  I also can't help with the brackets as I went 350 sbc... Mike B  | | | | | Joined: Jan 2005 Posts: 75 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 75 | I've had good success with Buffalo enterprises for the pump mount and CPP for their conversion kit. CPP might have their own steering box now. I used a Toyota box. | | | | | Joined: Feb 2015 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 33 | Hi, can I ask you Bob, how difficult was this project. You found CPP to be helpful? Curious why a Toyota pump vs. a GM product ? Thanks kevin
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | CPP, Classic Trucks, POL.....depends on your skills and welding equip and budget as to what kind is for you. I prefer the type using good old Chevy box and pump. Pump brackets can be fab'ed, modify one or purchase.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2015 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 33 | Thanks, Not too good at welding so I guess I will look around, sure I could take the Steering column out and have someone weld the rag joint in if needed. Thanks
| | | | | Joined: Jan 2005 Posts: 75 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 75 | Keven1957. Your PM box is at the limit. I don't know what that means. Toyota box mounts inside the frame and works well with stock steering column. CPP makes a kit to make it easy. | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | The Toyota box (84-87 4X4)is compact and has the same number of turns as the stock box. The sector shaft also comes out the side as does the stock box. The metric issue can be easily overcome by any hose shop. I installed one in my 56 in 2000 and it has many trouble free miles. It came as a kit which included a mounting bracket, drag link, coupler, steering box, bolts, and hoses for the GM pump. I modified the stock column. The current price for the kit probably about $700 not including the pump, pump brackets, & pulley. I did not purchase mine from CPP. Fred
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Curious about the axle mounted R&P. It has to have a slip joint in the steering shaft. Does the slip joint have a grease zerk or does it have some type of plastic in it? I would think the shackles and spring eye bushings would need to be in good shape to keep the shaft aligned to the slip joint. Once I used a Toyota box I've never considered anything else.
Evan
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I'm using an IDIDIT column with their Double-D slip joint...there are no zerk fittings on my set up. I need to look at it to see if they would even be feasable...I think the Double -D is open on both ends. Mike B  | | | | | Joined: Feb 2015 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 33 | Hi guys, Happy New Year! I am interested in your opinions about a rack and pinion power steering upgrade vs. a typical CCP type upgrade with new power steering box. Is there any advantages between one or the other? It seems the R+P type is a bolt on where a Saginaw type setup requires some modifications. I currently have a straight axle suspension and is powered by the original 235 with 3 on the tree tranny. My current steering box is original and as you can figure has a lot of play in it. Should I plan on changing the steering column and box in either case. My goal would be keep the truck original if I can so I didn't plan on changing the engine at this point. Any thoughts would be greatly appreciated. Kevin
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Nothing wrong with keeping it original. If we are talking about a 1957 3100 just rebuild what you have. Have you confirmed the tie rod and drag link ends are all good (no play when rocking the steering wheel)? What about the King Pins? Have you adjusted the steering box per the Shop Manual instructions? It will take a lot more money and effort to install a different steering system than it will to fix the original...new parts are available. Mike B  | | | | | Joined: Feb 2015 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 33 | Thanks Mike, hadn't thought of going that route. That's great advice, I guess I thought that the steering system was as good as it gets, I need to do some more research. Thanks again
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Rack & pinion steering on a straight axle is a disaster waiting to happen. The link from the steering column to the R&P has a nasty habit of getting a bind and locking up, usually at the worst possible moment in a tight turn due to body lean and/or a rough road surface. The necessity for the linkage to change length and undergo extreme angular changes of the universal joints at the same time can, and usually does result in the parts getting into a mechanical bind. Jerry
| | | | | Joined: Feb 2015 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 33 | Thanks that makes sense. I think I am going to check out the original steering system and makes adjustments as I can. Thanks Kevin
