| | | Forums66 Topics128,050 Posts1,055,759 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2014 Posts: 63 | I need to clean the air filter on my 1948 Chevy truck (oil bath). The filter has a label which says to use Kerosine to clean. Is there a better way or product to do this? | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | pretty much any solvent that will cut grease. you need to be aware of the volatility/flammability level of whatever it is you end up using. And act accordingly. Personally I would stay away from water based cleaners, that is just what we need, to contaminate a little bit more freshwater. There is a lot of advice/information that was given back then that can be improved upon nowadays. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I use kerosene or diesel fuel. In the open/shade - no flames or sparks nearby.
| | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | I use brake cleaner.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Been using kerosene in my solvent tank for 40 years now. Change it out every so often and donate it to the guy down the street who heats his garage with a waste oil burner. He's glad to get some real heating oil mixed in with the drain oil. Kerosene and diesel both have relatively high flash points so they are fairly safe to use as long as you apply some common sense to it.
As to your question, use any solvent, idea being that you just want to flush out the crud that's been sucked thru the filter. Then add your fresh oil.
dg
Denny G Sandwich, IL
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | If you like your paint and decal be careful picking your solvent as many will also dissolve the paint. Mike B  | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | MS-140 Mineral Spirits (also sold under the brand name "Varsol") is safer than kerosene- - - -much higher flash point. Jerry
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | clhaney- I have some of the "orange citrus" liquid cleaner I use sometimes. Sort of pricey but does a good job.
...don't want to hi-jack this thread, move it if needed, but here goes. QUESTION: Does anyone know of something that can be added to varsol,kerosene and similar stuff to "mask" the smell?....unless its worst than the cleaner!
The smell of most cleaners I've used lately, including Varsol and kerosene, cause my sinus's & stomach, to give me a very hard time especially since my surgery back in May. With it being winter time and being closed up in the shop its even worst...and yes, I keep the lid closed. Just asking. Thanks. | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Try a little Oil of Wintergreen- - - - -most drug stores sell it, or it's probably available on Ebay. There's an oldtime oilfield workers' trick to mask the distinctive smell of "drip", an untaxed byproduct of crude oil production that will run a gasoline engine- - - -add a bottle of wintergreen to each tank of "gas" collected from the wellhead drips. One of the guys in my Air Force unit told me about that little trick. He came from a large family of Texas oil workers. It might mask the smell of Varsol the same way. Jerry
| | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | If you want to clean it why use an oil? (diesel and kerosene are oils)
Get a gallon of mineral spirits. That will clean it and anything else petroleum based.
From my TM "... wash all parts in volatile mineral spirits paint thinner or dry-cleaning solvent, dry thoroughly, and reassemble."
Kero and diesel will not readily ignite. The VAPORS are what burn. You can put out a match with kero/diesel... | | |
