2 members (Millenimech, klhansen), 161 guests, and 1 robot.
Topics128,115
Posts1,056,289
Members48,439
Getting ready to install my new windless channel. My question is, can I use screws for attachment and what size / type?
Thanks.
Mike
windlace - door opening weatherstrip
Do you have the channel retainers (grooved retainers) or the screw-in retainers? Most likely you have channel/grooved retainers? No screws were used. If you are going to screw them in - the choice of size is whatever works and looks right to you.
If someone posts a reply who used screws in the channel/grooved retainers, please post links to photos.
http://www.classicparts.com/Retainers-Hardware/products/812/2/0 Found these at Classicparts, if that's what you're talking about
"When I rest, I rust"
1951 3100 5 window w/ '56 235
I used these to reattach a section of channel on my 50
...#8 x 1/2 inch
windlace -
...pic...
...pic...
...pic...
Yes - if it works, go with it.
I also found screws on the passenger side lower cowl
Those slotted screw must of installed prior to the early 70s
...pic..
Former BMW Rider
Former BMW Rider
Does anyone have a source for the flat retainers that install with screws?
All I have is a series of screw holes around the door openings in the cab.
Andy
His: 1947 Chevrolet 3104
Hers: 2008 American Saddlebred
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
These are listed for 48. Don't know if they will work on your 47?
...link...
...link...
That is a misrepresentation of what they are selling. Those are c-channel retainers for mid '49 through '55 first series.
Carl
Classic Parts has the windlace channel guides almost properly dated - 1949-1955st:
Left Side door opening
Right Side door opening
Are the 47's diffrent?
Exposed screws ?
Former BMW Rider
Former BMW Rider
Exposed screws ?
Yes, see the first paragraph of the 1947 Truck Shop Manual.
Tim's first post had a good diagram that shows the differences between the 47/48 through 49/54 windlace retainers.
Andy
so what im getting here is you have to use the later channel type
or fab your own for the early trucks
Former BMW Rider
Former BMW Rider
jacksun,
The holes for mounting the windlace channel on the 47 through early 49 are threaded. It's my understanding the late 49 through 54 windlace channels are welded in place.
It's possible to make your own windlace channels that resemble the 47 thru early 49; however, that could be quite a project.
I was able to find windlace channels for my 47 in the "Truck Parts Wanted" forum. They are out there and some are in pretty good shape too!
Andy
Moderated by  ndkid275, Phak1
