5 members (Otto Skorzeny, jmoore, Hotrod Lincoln, Bill Hanlon, Ponchogl), 127 guests, and 0 robots.
Topics128,105
Posts1,056,209
Members48,436
Looking for a "how to" to remove and replace the bushings that are in the pedal for the brake and clutch on my 46 truck. Mine are pretty worn and wobbly.
First I try to punch them out with a screwdriver on the edge but most of the time I simply put a hacksaw blade thru the bushing and saw it into then twist it out. You can also use some heat but I never have.
...if the new bushing won't push back in with relative ease then put them in the freezer for an hour and they'll shrink and will be easy to drop in. Good luck.
Ditto what Alvin said - and you may have to hone the I.D. to get a smooth pedal. I used a brake cylinder hone and it worked great.
how do you get the pedal arm off the assembly?
The pic below is off my 52panel. I think yours is mounted to the tranny but the shaft the pedal fits on will be held on with something similar. Its been since 1985 that I had a '46.
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/BrakeClutchlineup.jpg
...have you checked the online shop manuals?
thanks achipmunk, the picture does help.
