4 members (TooMany2count, MNSmith, moparguy, TexasJim50), 56 guests, and 5 robots.
Topics128,014
Posts1,055,324
Members48,419
#108479 01/09/2005 12:08 AM
Thinking about buying a Stud Welder to pull a bunch of dents on my 59. My thought was that it would save a lot of time over hammering. I was looking at the H&S 5500. I'm looking for your thoughts on this plan and if anyone has experience with this welder. As always, thanx for your help.
59 Apache
1959 Chevy Apache Stepside 4x4
2009 Chevy Silverado 2500HD Duramax/Allison LB Crew Cab
#108480 01/09/2005 12:46 AM
I used a cheap one on my 64 but it only worked, like it was supposed to, on the larger areas of sheet metal. The metal is just too tough back then to pull dents close to a bend or a seam. Maybe a better welder will do heavier guage sheet metal,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#108481 01/09/2005 3:14 AM
When I'm working at the shop on older vehicles with thicker metal, I switch to larger studs on the uni-spotter so I have more pulling power. They sale the studs in 2.0 mm, 2.2 mm, 2.5 mm and I believe 2.6 mm. They don't always pull out dents especially on corners but it doesn't hurt to try before you crawl have to pound the dent out from behind........."when you have access that is" smile
Joe
#108482 01/09/2005 6:57 AM
The thickness of the metal was one of my concerns. I wasn't sure if the 5500 could weld a stud strong enough to pull out a dent.
