| | | Forums66 Topics128,088 Posts1,056,124 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 1,002 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,002 | I'm considering a front disc brake conversion on my 41 3/4 ton. I could have swore that I read the only difference on the front suspension (except brake sizes) was the size of the axle itself (3/4 is thicker). All other components are the same size; king pins, wheel bearings, and spindle.
I was just told by a vender that is not true. 1/2 ton and 3/4 ton have different spindles, so their disc brake conversion kit will not work on a 3/4 ton.
Could someone please clarify this for me so I know what to look for? Thanks,
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Jun 2005 Posts: 1,002 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,002 | This is where I saw the information. Doesn't it translate into 1/2 and 3/4 having the same spindle size? 1941 Specs
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Jun 2005 Posts: 1,002 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,002 | Thanks Frank50.
They're 8 lug wheels. I read over those links a couple of times but still did not see the answer.
So, since it's 8 lug it's heavy duty and I should be looking at the "Heavy Duty & School Bus, Regular Axle" section on the Spec. Sheet?
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | Looks like it. You should be able to data mine this site for lots of old Chevy info, including GM part numbers... http://chevy.oldcarmanualproject.com/Good luck with your truck!
Professional Novice
