8 members (1955 1 Series, klhansen, John Dlugos, Bill Hanlon, Gray_Ghost, Otto Skorzeny, 2 invisible), 219 guests, and 2 robots.
Topics128,101
Posts1,056,179
Members48,436
#1084671 02/09/2015 7:10 PM
V
VEW
Offline
V Offline
I'm considering a front disc brake conversion on my 41 3/4 ton. I could have swore that I read the only difference on the front suspension (except brake sizes) was the size of the axle itself (3/4 is thicker). All other components are the same size; king pins, wheel bearings, and spindle.
I was just told by a vender that is not true. 1/2 ton and 3/4 ton have different spindles, so their disc brake conversion kit will not work on a 3/4 ton.
Could someone please clarify this for me so I know what to look for?
~ Victor
1957 3100 - moved on
V
VEW
Offline
V Offline
This is where I saw the information. Doesn't it translate into 1/2 and 3/4 having the same spindle size?
1941 Specs
~ Victor
Does your truck have 8 or 6 wheel lug bolts? If 6 then it is a 3/4-ton Light Duty. See the links below:
http://www.stovebolt.com/techtips/art%20deco/index.html
http://www.stovebolt.com/techtips/tranny/bonds/index.html
If it is a Light Duty then the spindles, king-pins, bearings and brakes are the same as 1/2-ton.
Professional Novice
V
VEW
Offline
V Offline
Thanks Frank50.
They're 8 lug wheels. I read over those links a couple of times but still did not see the answer.
So, since it's 8 lug it's heavy duty and I should be looking at the "Heavy Duty & School Bus, Regular Axle" section on the Spec. Sheet?
~ Victor
Looks like it.
You should be able to data mine this site for lots of old Chevy info, including GM part numbers...
http://chevy.oldcarmanualproject.com/
Good luck with your truck!
Professional Novice
