Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Forty9, Guitplayer, Bill Hanlon), 168 guests, and 4 robots.
Topics128,279
Posts1,058,582
Members48,492
Page 7 of 8 1 2 3 4 5 6 7 8
Hi. I would like to have some info on your IFS crossmember for a 51 chevy 3100 pu (also list of associated donor a arms and such) and cost. thanks phil
Welcome aboard hopalong....I had replied to your email. Where in Florida are you?
Tampa ............in the 70's today.....hanging out on the deck
Hi. I would like to have some info on your IFS crossmember for a 54 chevy 3600. A list of associated donor parts if you have one.
Thanks Paul
What info are you looking for specifically. GM Metric donor vehicles are the 1978-1987 GM A/G bodies and the 1982-2004 S/T bodies.
Will your crossmember fit an 3/4 ton? Does the donor parts mount to your crossmemer? I would like to use rack and pinion. Maybe some pictures of a completed install. Any info on adapting the existing steering column if possible.
yes, it fits a 3/4 ton
here is the link again for photos
http://s1343.photobucket.com/user/scott_danforth/library/Crossmember%20Customers?sort=3&page=1
my kit is set up for a rack and pinion.
to use the stock column, remove the stock gear box, use a 3/4" ag bearing from tractor supply (same od as the id of the steering column tube. grind a double d end on the shaft for a steering u-joint.
I was looking at a manual rack and pinion. Will this work? Any recommendations. Can I get a price for your crossmember?
you can use a manual rack. My recommendation is sweet or appleton, however you are free to use anything you want.
my kit is $500 plus shipping.
I used S10 blazer parts
1988 CHEVROLET S10 PICKUP 4.3L 262cid V6
DORMAN 697904 (697-904)
Knuckle
DORMAN 520135 (520-135)
Control Arm
DORMAN 520137 (520-137)
Control Arm
DORMAN 697905 (697-905)
Knuckle
DORMAN 520136 (520-136)
Control Arm
2003 Blazer 4.3 v6
ACDELCO 18R1372
Caliper
ACDELCO 18A862A
Rotor
ACDELCO 18R1373
Caliper
Dave Chapman
The Hollister Road Company
713-937-0387
[email protected]
www.hollisterroad.com
www.thoroco.com
Originally Posted by GeneHarris
Can you give me an example of S/T body style. I am trying to build a component list. I am not finding a lot on the internet.
Any 1982-2004 S-10, S-15, T-10, T-15, S-10 Blaser, Sonoma, Hombre, Bravada, Jimmy, Cyclone, Typhon, etc. Technically GMT-325 and GMT-330 chassis
These are the same stampings as any A/G body which is any 1978-1987 Malibu, Regal, Monte Carlo, Cutlass, El Camino, Gran National, etc.
Just to add a little info. Prior to I think 1998 the S/T trucks used a regular spindle and cone bearing, 2002 used a hub assembly. So all the A/G will be regular spindles and cone bearings as will 82-97 S and T trucks
Dave Chapman
713-937-0387
[email protected]
www.thoroco.com
correct. the hub assembly also interchanges with the Camaro and corvette. and the 1998 and later S-10 blazers come with dual piston calipers.
This is important only when getting brakes and buying lowering spindles. as the GM metric components are interchangeable, just like parts on Mr Potato head.
Moderated
Moderated
very interested in one of you crossmembers.could you please contact me at [email protected] .thank you
What is the preferred donor Rack and Pinion?
Click the link to see my truck.
http://smu.gs/OuBwfv
the 1993-1997 Camaro or Firebird. in 1998, they changed the angle of the pinion and it hits the frame. simply cut off 4-1/8" off the inner tie rod ends and rethread.
however if you desire, a ford exploder or dodge durango/dakota rack and pinion can be used as well.
What setup provides the best turn radius?
The 87 Tbird rack I used goes stop to stop on stock S10 spindles. I haven't driven it yet but i'm expecting a turn radius about the same as a long bed S10
Dave Chapman
713-937-0387
[email protected]
www.thoroco.com
the best turn radius will be a Sweet or Appleton Rack, or aftermarket spindles (Coleman Racing) with shortened bolt-on steering arms.
Has anybody tried using a stock S-10 steering box
Hi Scott new bolter here I bought your crossmember off another forum from someone that bought it and never installed it they lost the instructions and parts list. Would like to find out how I could get another set thank you in advance
I was going to use a s10 box but it would take more work that it was worth. I used a 98 Mark VIII rack with a 6" throw. It goes stop to stop and turns nicely
A-1 CARDONE 22215 (22-215) $165. you may have to trim a little off the tierods
Dave Chapman
713-937-0387
[email protected]
www.thoroco.com
What was the main problem with using the S-10 box?
The cost of the rack does not concern me......but needing a pump and lines.....and then dealing with the volume differences does.
nothing to mount the box to
the pump is a GM with a pressure reducer kit and some lines from borgeson
Dave Chapman
713-937-0387
[email protected]
www.thoroco.com
Mike,
Since the frame is between the width of an S-10 and a G-body, you would have to create your own geometry, make jigs to mount everything, and fabricate your own mounts and center link.
I spent a long time trying to make it work. Not saying you cant, however the amount of work needed to get the steering so the ackerman geometry is right, it doesn’t bind, or introduce bump steer was infinitely more difficult than simply going rack.
Scott.
My guess is you bought Justin's kit? PM me your contact info.
Thank you Scott he found the instructions and I will have them soon. Can't wait to get started on the install.
Moderated
Moderated
Scott,
I found your email on a facebook page build and would like to purchase on of your crossmembers. I emailed you on 10/2/15. I can't seem to private message on this board. Thank you. Tim Fountain
Red dot, center of chest ...
You are under moderation. Until you've had four posts approved, you can't use PM.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
Moderated
Moderated
Thank You Baldeagle. I guess this will keep the spammers away.
Yes, we've actually had spammers register and then PM every member with their crap. Very few of them seem to have the patience to post four times. grin
Paul Schmehl CI 6
geek@stovebolt.com
Tim,
I have not recieved any email from you. However my email address is in my profile on here.
Scott
Hello to all, new member with lots of questions, found Stovebolt with link from another site. My son has '50 AD with original front & rear suspension. I have read this thread, does Scott have his crossmember available bolt-in?
I found Scott's email address a few pages back sent him a request.
Donny, glad to have you here. send you an email.
Moderated
Moderated
Scott, I am interested in your cross member could i get some info. I have a 50 GM 1/2 ton
Frank, I would PM you, however you only have one post, and did not update your profile with your email.
what information do you need that isnt covered in these posts? email me at [email protected].
Scott
Bringing this back up...
I am working on a 1952 3100 1/2 ton Chevy pickup. The truck is almost all stock currently. The plan is to install a SBC, T5, and most likely a 2nd Gen Camaro rear axle.
I am in the investigation mode to IFS set-ups. Not planning on any subframe splices or anything. At this point trying to decide what Mustang II IFS set-up suits my needs (quality, functionality, cost, etc.).
I am not looking for Wilwood brakes, polished components, as I am after the improved driveability aspects.
Bolt-in parts would be nice, to make at least one part easier, but I could use your thoughts and opinions!!
Thank you,
Rich
1952 Chevy 3100 (235CI engine)
...T5 swap in progress...
Scott,
Are you still selling the cross member? This will be going in a 49' 3100.
Wheels
Blair
1949 3100 5 window
[email protected]
Yes. PM me your zip. $475 plus shipping
