4 members (Otto Skorzeny, Materman, mason86, GRNHydra), 100 guests, and 2 robots.
Topics128,069
Posts1,055,890
Members48,428
#1083790 02/05/2015 6:08 PM
What columns are you guys happy with or what is the best bang for the buck ? also has anybody used the imported columns and are they any good ???
THANKS
BILL
Scotty, I have NOT done this but over years of reading what others have done I've read many times that a column out of a Chevy Van (80's?) if about 30, or 31 inches and works great. I'm not sure, but I also think it is a small column so your key/switch would/could stay in the original dash position.
....I'm sure someone will be along later to answer your particular question.
Lots of aftermarket stuff out there. IDIDIT offers a quality product. A bit pricey so it depends on your budget.
I have more zippers then a pair of cargo pants
I used a 94 Buick Park Ave FWD tilt column & modified it by swapping out the collar to get rid of that ugly square box & used a late 70's tilt collar. I used a collar from a 79 Cadillac. It was modified by cutting about 1/2 inch or so off the top so it was the same as the stock one. I also used the Cadillac turn signal switch. I used these parts because it was something I had it. You could use any GM tilt collar that doesn't have that box to do this swap.
Finished column....
~ Joe
Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE.
Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke
if you use a after market use a idit or flaming river their inside u joint are steel [not plasitc with a metal pin that can break]. giving you a free turning steering wheel and no steering.[ ask me how i know]
1 used a 75 chevy van Colum...I sent it out to a guy In Missouri who went thru the electrics and shortened it and removed the shifter boss and filled the hole.....I use the stock Colum drop at the dash and a ididit 55 chevy car floor mount......dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
CPP has some nice columns for around 300 bucks good price. Ididit and Flaming river are way to much in my opinion.
I bought an unpainted IDIDIT and was going to paint it but the machine finish is like brushed stainless so I am going to clear coat it and it will match the gauges.
You get what you pay for. We put an Ididit into a 30 Plymouth taxi and it had a problem; turning the steering wheel would move the shift lever. Sent it back and within five days it was returned with an apology stating it was their fault, a check for shipping, and a note saying that since it was a painted column if it got scratched during re-installation to send them a bill for refinishing. Wonder what would happen with one of the foreign cheapies?
Evan
