5 members (NJC, 32Fordpuchoptop, 48jim1ton, BillyDon, Jman), 94 guests, and 3 robots.
Topics128,042
Posts1,055,601
#1083464 02/04/2015 1:07 AM
Where can I buy rear axles for my 1948 1/2 ton 3100? Mine are worn at the bearings. Thanks
Dennis
oldbluetruck #1083506 02/04/2015 3:38 AM
I've never had to do it but you can get a "shim" to put on the axle, maybe consider having someone build it up and turn it back to size....or put an ad in the parts wanted forum for a few days. Someone putting in a late model rear-end may have one on hand. A little expensive but we have a 4x4 shop in Greenville, S.C. that can cut you a new axle.
Lot of years will work in your housing if my 52 is the same as a 48....I THINK up to '62, ('ve used a 59 in my 52 so I know that works)
....and you could put a shim behind the seal so that the seal lip is not riding in the same place on the axle and may be alright......I'm sure someone will come along with better answers but this should get you started.
oldbluetruck #1083607 02/04/2015 7:28 PM
Thanks Alvin. I hope there is a source. My truck is apart at a shop.
Dennis
oldbluetruck #1083832 02/05/2015 9:37 PM
Riding in the Passing Lane
I have one from a 56 but I'm not sure if its the same length. Sounds like your problem is more then a seal surface. The roller brg rides on the axle & can score the surface.
1972 Chevy c10 Cheyenne Super
If it's the race, it is a separate part. Had to do one on my '46 1/2 ton. Part number is 111121 - fits 40-57 1/2 ton. Axles are made of unobtainium in my experience. Might want to check in with Pre '68 Dave - he helped me out with a race.
David
