| | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Where can I buy rear axles for my 1948 1/2 ton 3100? Mine are worn at the bearings. Thanks
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I've never had to do it but you can get a "shim" to put on the axle, maybe consider having someone build it up and turn it back to size....or put an ad in the parts wanted forum for a few days. Someone putting in a late model rear-end may have one on hand. A little expensive but we have a 4x4 shop in Greenville, S.C. that can cut you a new axle. Lot of years will work in your housing if my 52 is the same as a 48....I THINK up to '62, ('ve used a 59 in my 52 so I know that works)
....and you could put a shim behind the seal so that the seal lip is not riding in the same place on the axle and may be alright......I'm sure someone will come along with better answers but this should get you started. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Thanks Alvin. I hope there is a source. My truck is apart at a shop.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I have one from a 56 but I'm not sure if its the same length. Sounds like your problem is more then a seal surface. The roller brg rides on the axle & can score the surface. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2008 Posts: 298 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 298 | If it's the race, it is a separate part. Had to do one on my '46 1/2 ton. Part number is 111121 - fits 40-57 1/2 ton. Axles are made of unobtainium in my experience. Might want to check in with Pre '68 Dave - he helped me out with a race.
David
