1 members (Hotrod Lincoln),
327
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2014 Posts: 136 Shop Shark | | Shop Shark Joined: Oct 2014 Posts: 136 | So what is the story on the passenger side cowl vent on a '53 Chevy 3100?
The reason I ask is the one on my truck appears to be totally useless. There are the louvers on the outside body that allow air into the cavity between the inner and outer sheet metal. On the inside, there is what appears to be an original factory plate screwed over the opening in the inner panel.
Were there some trucks that had some kind of vent there?
'53 3100 5-window '57 Mercury Monterey 2-Door Sedan Tim H
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The dealer installed fresh air heater bolted to where the cover plate is. With the recirculating heater and aftermarket heaters the cover stayed in place. | | | | | Joined: Oct 2008 Posts: 48 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 48 | Didn't some AD years have a vent door that could be opened to let in fresh air? If there is such a thing I need one. I thought I saw one on some of these trucks before. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | There was a vent door on the driver side from '47-50. It was eliminated when the vent windows were introduced. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Mar 2010 Posts: 10,307 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,307 | What years were the Deluxe Airflow heater available? Carl
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | A somewhat similar in appearance Airflow (Air Flow) or Fresh-Air Heater was available as a GM Accessory from 1947-1955 (A-D years). They all used outside air from that that lower right cowl opening.
In 1953-55, the cable controlled inside/outside air and from 47-52 the cable controlled the defroster flap.
GM's use of the terms Air Flow and Fresh Air over 47-55 is confusing and not consistent with changes made in 1953.
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Didn't some AD years have a vent door that could be opened to let in fresh air? If there is such a thing I need one. I thought I saw one on some of these trucks before. I have seen passenger (RH) side opening 'crotch cooler' vents on RH Drive trucks such as Australian and South African models,although Cletis is correct about the American/Canadian spec trucks.
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Oct 2014 Posts: 136 Shop Shark | | Shop Shark Joined: Oct 2014 Posts: 136 | Thank You to all who replied. The answers confirmed my thought that as far as I am concerned, on my truck, the passenger side cowl vent is useless.
The instructions for the AC/Heat unit I am going to install says to close off the vent and recommends putting insulation in the cavity between the outer and inner sheet metal.
My thought was to weld and seal a piece of sheet metal on the inside of the louvers, leaving them on the outside for a stock appearance.
My wife, on the other hand, says I should cut out the louvers and weld in a smooth piece of sheet metal. She says, "there are no louvers on the driver's side".
I am going to weld the upper cowl vent shut and seal it because over the years it has been a source of water under the dash and down the inside of the firewall. My thinking on closing off the louvers (either method mentioned above) is the same, seal off potential sources of water.
Thoughts?
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I hear you lynngrove, but I must admit, I like the vent cowl in spring and fall weather...... but I don't have A/C yet!
If your trying to keep your pickup at least looking stock I'd leave the louvers and do your plan of sealing it off. Just my .02 | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I hear you lynngrove, but I must admit, I like the vent cowl in spring and fall weather...... but I don't have A/C yet! It never really gets warm enough here to justify the expense of A/C here Alvin,I just open the cowl vent and drive faster!  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Been down in the teens and twentys this month here outside of Chicago. Been driving the '5O a couple times a week, without earmuffs or scarf. I've actually got the heater valved off at the water pump because my Deluxe heater core has a tiny leak. But there is still enough hot water seeping past the shutoff that the core gets hot. With the blower on high the cab is quite comfortable. Drove her for a while yesterday, was a cloudy day but it was still nice inside the cab. AC in the summer, might be nice when you're standing still, but with the side and cowl vents open as long as you are moving along again, it's quite comfortable in the cab.
Even though Blue's not a show truck, a couple of years back we took part in the Oswego Drag Strip Days car show. This is a biggie around these parts, they closed down the entire town and filled all the parking places with show cars. It took almost an hour to get from the staging area across the river and into town, so we were idling in traffic on a sweltering September day for about an hour. Surprisingly it wasn't all that bad in the cab since there was a little bit of a breeze blowing. DG
Denny G Sandwich, IL
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | From what I understand,the deluxe air flow(fresh air) in my picture was available for 1953 to 1955.1 series trucks.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Mar 2010 Posts: 10,307 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,307 | From what I understand,the deluxe air flow(fresh air) in my picture was available for 1953 to 1955.1 series trucks.
Tim Thanks Tim. I have one of those and wanted to put it in my '52 which I am trying to make as built. Now it will go in my '50 daily driver and use my other standard fresh air heater in the 52. Carl
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | my 52 panel had the fresh air heater and I believe it to be original. Hadn't really done any research on it. I rebuilt my system but plan to go with an "all in one" A/C-heater. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Tim with the Bow Tie, just spent an hour with your pictures, thanks. I feel I've been thru this discussion before but, what paint did you use in the restoration of those two heaters? Very nice job of restoring them to their original appearance. I've been looking for a Deluxe Fresh Air heater for my '54 since I brought it home 5 years ago. Bought a couple from a guy here on the bolt, both stuffed into a box and both turned out to be way to rusted up to salvage, literally no usable parts on either of them. Good way to get rid of that rusty scrap in the corner of the garage. That was a wasted couple hundred bucks. But I'll keep looking. Thanks, Denny Graham Sandwich, IL
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Denny,I used Rust-Oleum Hammered Finish type #7218 dark bronze. rust-oleum dark bronze 7218 dark bronze I know it's not the factory spec color,but it's close for me. Thanks;Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Looks great, can't believe it's not all bumpy like hammertone is every time I've applied it. I'm experiencing deja vu cus I'd swear we've had this discussion before. Well---that refreshes my memory and should help out any new be that missed it the first time around. It was probably noted in my reference archive but I lost the first 9 years worth to a computer failure and monster move. Thanks Tim, Denny G Sandwich, IL
