6 members (SmalltownTRKGuy, Otto Skorzeny, moparguy, Gdads51, dt235sd, 1 invisible), 76 guests, and 4 robots.
Topics128,094
Posts1,056,056
Members48,433
#1081537 01/26/2015 4:35 AM
I am building a 49 3100 with a 350 and I am about ready for exhaust manifolds I know that the rams horn manifolds are what I need but I have two questions first are the after market cast iron manifolds good quality and second, does anybody make a cast iron manifold that is better looking than the stockers and possibly ceramic coated ? ? ?
THANKS
BILL
No experience with the repops, but the old original 300 HP 327 ram's horn manifolds with the 2 1/2" pipes were some of the best I ever ran on my dyno. Other than a tuned header with equal-length pipes for all cylinders, they gave the best torque output over a wide range of RPM. Even regular unequal-length tube headers couldn't match their performance.
I think Sanderson makes a coated ram horn.
I used some aftermarket rams horns that came from Dorman Products on a job a couple of years ago. They were relatively inexpensive and seemed to be of good quality. I see lots of the standard 2" manifolds at swap meets but the 2 1/2" originals are becomming scarce and pricy as well.
Fred
speedwaymotors.com has quite a selection of rams horn manifolds with any coating you want. They also sell a tru-ram manifold, much cleaner than stock.
Had em on the 283 in the sub. took up very little space and worked good with stock sounding mufflers I think they were 2".
Weeds
Weeds
I used the Sanderson block huggers on my 58 gmc. Working great and no clearance problems. I know my blue chip truck has a little more room than your 49 but that saying I remember long years ago a 50 gmc I had with rams horns was real close. Wish I'd had the sanderson back then.Larry
58 gmc 100 with 350 sbc
I ended up using exhaust manifold for 67-72 truck...plenty of clearance for steering shaft with 2 u joints CarParts wholesale Lasalle Illinois.
