| | | Forums66 Topics128,120 Posts1,056,321 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2015 Posts: 37 | I am building a 49 3100 with a 350 and I am about ready for exhaust manifolds I know that the rams horn manifolds are what I need but I have two questions first are the after market cast iron manifolds good quality and second, does anybody make a cast iron manifold that is better looking than the stockers and possibly ceramic coated ? ? ? THANKS BILL | | | | | Joined: Feb 2004 Posts: 29,807 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,807 | No experience with the repops, but the old original 300 HP 327 ram's horn manifolds with the 2 1/2" pipes were some of the best I ever ran on my dyno. Other than a tuned header with equal-length pipes for all cylinders, they gave the best torque output over a wide range of RPM. Even regular unequal-length tube headers couldn't match their performance. Jerry
| | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | I think Sanderson makes a coated ram horn.
| | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | I used some aftermarket rams horns that came from Dorman Products on a job a couple of years ago. They were relatively inexpensive and seemed to be of good quality. I see lots of the standard 2" manifolds at swap meets but the 2 1/2" originals are becomming scarce and pricy as well. Fred
| | | | | Joined: Oct 2004 Posts: 128 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 128 | speedwaymotors.com has quite a selection of rams horn manifolds with any coating you want. They also sell a tru-ram manifold, much cleaner than stock. John | | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Had em on the 283 in the sub. took up very little space and worked good with stock sounding mufflers I think they were 2".
Weeds
Weeds
| | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | I used the Sanderson block huggers on my 58 gmc. Working great and no clearance problems. I know my blue chip truck has a little more room than your 49 but that saying I remember long years ago a 50 gmc I had with rams horns was real close. Wish I'd had the sanderson back then.Larry
58 gmc 100 with 350 sbc
| | | | | Joined: Jul 2014 Posts: 12 New Guy | | New Guy Joined: Jul 2014 Posts: 12 | I ended up using exhaust manifold for 67-72 truck...plenty of clearance for steering shaft with 2 u joints CarParts wholesale Lasalle Illinois. | | |
