1 members (Hotrod Lincoln), 57 guests, and 1 robot.
Topics128,094
Posts1,056,066
Members48,433
#1078540 01/11/2015 3:32 AM
I want to put a 292 with sm420 in my 48 3/4 ton with bellhousing / crossmember will work? The 292 bellhousing is angled mounted to the crossmember. will just a 1954 - 1955 crossmember work or can i use a crossmember up to the late sixty? I know there riveted in. I was thinking of cutting the rivets out and bolting it back in
pjberg #1078543 01/11/2015 4:13 AM
I am unsure of the 292 fit requirements but can speak to the 54' crossmember in a 47-53 truck. I put this crossmember into my 50' with a 54' 235 and it is pretty simple. You grind the rivets off the early one and the 54' version will only require a small amount of hole reaming to fit. The holes are only about an 1/8-1/4 inch off in total and the 235/SM420 bolt right up with the 54' bell housing.
https://www.flickr.com/photos/advance-design_parts_co/8129099972/in/set-72157631867396207
pjberg #1078559 01/11/2015 5:06 AM
Thats what i need to find. I believe 292 bellhousing will work
the same way i just need to find one
pjberg #1081109 01/24/2015 3:11 AM
I just put one in a 47 you need a late 50's v8 bell and modify the rear cross member to accept the tapered ears
http://www.thehollisterroadcompany.com/media/1947_3800/FrameAxle/473800frame%20003.JPG
The 292 front mounts will have to be fabed, 230 250 mounts won't work, The original clutch pedal will still work.
Dave Chapman
The Hollister Road Company
713-937-0387
[email protected]
www.hollisterroad.com
www.thoroco.com
