0 members (),
137
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Had a conversation with a truck friend of mine and we were discussing the length of shock needed for the GMC ride he is building. I generally measure and see what is available with about half exposed which means half in or half out....I've used a few other methods on what I "thought" would work better due to weight.
...so what do you guys use as a "rule of thumb" when buying the correct length of shock? Thanks for you input. | | | | | Joined: Jul 2013 Posts: 160 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 160 | I recall searching tech stuff on the net that 60% of the total travel should be available for compression from ride height. Sorry don't recall the site but it seems a logical estimate when you think about the forces a shock sees- much higher on compression than rebound. | | | | | Joined: May 2013 Posts: 27 New Guy | | New Guy Joined: May 2013 Posts: 27 | I agree. I mostly build rock crawlers but am working on a 1956 3600 build as well. Ideally you should cycle the suspension and measure full compression and full extension. However, at ride height I generally give 60% of the shock travel to compression and 40% to extension. In the rear application of a truck I would think this would be even more crucial as the ride height is generally a bit higher in the rear to account for loading of the bed or a trailer. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Thanks guys. At least I've been close all these years at 50/50 and as mentioned, I use to consider the weight factor, but on the pickups I've messed with it rarely comes into play. Thanks for replying and I'm sure some others may chip in later. | | |
