| | | Forums66 Topics128,078 Posts1,056,024 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | My 49 has the tracks on the inside for door seals does anyone make those tracks? some of mine have been destroyed. Who makes the seals that go into those tracks ?
Also, is there a good reference of how the seals and weatherstripping are attached ? | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | found some good info in previous posts on how to install, but nothing that looks like the tracks (retainers) | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | is the track attached to the cab? are your referring to the windlace track? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | just-a-hacker,
Jim Carter truck parts used to sell short lengths of that track. You might to call them.
FYI: sometime in 1949 they changed to the tracks for that door "windlace". Prior to that, the windlace was held in place using screwed-in strips of metal.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Jim Carter item CB-350 it comes in 12" sections. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Classic Parts of America sells the complete windlace channel guides per side. left windlace channel guide right windlace channel guide Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | thanks, ordered the retainers from Jim Carter and the rubber from Steele products | | |
