0 members (),
62
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 123 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 123 | found a couple of nice 235 motors. They are from 55 & 57 chevys. I want to put it in my 50 to replace the 216. Does it matter if they are from a vehicle with an automatic. My setup is a four speed.??? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If it is from an automatic setup, you will need to install a pilot bushing in the4 crankshaft. Normally one would put a new one in as part of the job. I guess I would ask the question, were all the crankshafts bored for the bushing? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | All the 1954 and later cranks I have seen are bored for a pilot bushing.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Besides that bushing, you'll need to address the longer and lower water pump pulley on the later 50s 235s. There is an adapter you can install that allows you to use the 216 type water pump or you can get a shortened water pump. However that shortened pump, will put the fan to low, so you should check out the adapter. Seen them on Ebay, search 235 water pump, should do it. Compare the fans/water pump loccations on both motors you'll see the issue.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
