Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
7 members (55shaker, Shade Baby, Bill Hanlon, Jon G, 78buckshot, TrknGMC, 1 invisible), 109 guests, and 3 robots.
Topics128,274
Posts1,058,436
Members48,490
#1079304 01/15/2015 2:10 AM
I have searched and can't manage to find the info I want about my distributor. It is a delco remy model# 1112363, serial #1B21. I'd like to know what this came from, year, make, model(s). And is it a 6v or 12v. Thanks for any help:)
http://www.secondchancegarage.com/public/1952-chevrolet-216-92hp-6-distributor-specs.cfm
Same model# code in 1951 - 6v 216 engine
I think (but please correct me) that 1B21 might be a date code?
1 = 1951
B = February
21 = 21st day
I have a Motor repair manual that lists that distributor number for a 1952 passenger car with a Powerglide transmission. That would make it a 235 with 6.7:1 compression and 105 HP, per the same manual. The car would have had a 6V ignition system, but the distributor doesn't care- - - -with the proper coil it will work on either voltage.
Ok. Thanks guys. I heard that if you put 12v to a 6v dist, that the points will arc more and result in a shorter life expectancy. Is this true? The '53 half ton that this distributor is going in will be 12v. I think I am going to use an internal resistor coil to knock the voltage down from 12 to 6v, rather than the firewall mounted resistor. Any opinions/input about this would be appreciated.
The distributor does not care if you use 6v or 12v. The points care. Your internal resistor coil will take care of the points.
The internal/external resistor debate has been beaten like a dead horse. General Motors chose a non-resistor coil and a ballast resistor as original equipment for millions of vehicles for a couple of decades. The self-appointed experts on the Stovebolt site are smarter than all the engineers who designed those systems, I guess!
Are the mechanical advance springs and weights the same for the automatic transmission and the manual transmission distributors?
My manual lists a slightly different advance curve, and a different distributor part number for standard/automatic applications. They are very close on the numbers, so I doubt the horsepower or torque differences could be noticed without a dyno run. Carburetor calibration would probably make a lot more difference than advance curve, IMHO.
