| | | Forums66 Topics128,051 Posts1,055,768 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 192 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 192 | I have searched and can't manage to find the info I want about my distributor. It is a delco remy model# 1112363, serial #1B21. I'd like to know what this came from, year, make, model(s). And is it a 6v or 12v. Thanks for any help:) | | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | I have a Motor repair manual that lists that distributor number for a 1952 passenger car with a Powerglide transmission. That would make it a 235 with 6.7:1 compression and 105 HP, per the same manual. The car would have had a 6V ignition system, but the distributor doesn't care- - - -with the proper coil it will work on either voltage. Jerry
| | | | | Joined: Jan 2015 Posts: 192 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 192 | Ok. Thanks guys. I heard that if you put 12v to a 6v dist, that the points will arc more and result in a shorter life expectancy. Is this true? The '53 half ton that this distributor is going in will be 12v. I think I am going to use an internal resistor coil to knock the voltage down from 12 to 6v, rather than the firewall mounted resistor. Any opinions/input about this would be appreciated. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The distributor does not care if you use 6v or 12v. The points care. Your internal resistor coil will take care of the points.
| | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | The internal/external resistor debate has been beaten like a dead horse. General Motors chose a non-resistor coil and a ballast resistor as original equipment for millions of vehicles for a couple of decades. The self-appointed experts on the Stovebolt site are smarter than all the engineers who designed those systems, I guess! Jerry
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Are the mechanical advance springs and weights the same for the automatic transmission and the manual transmission distributors?
| | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | My manual lists a slightly different advance curve, and a different distributor part number for standard/automatic applications. They are very close on the numbers, so I doubt the horsepower or torque differences could be noticed without a dyno run. Carburetor calibration would probably make a lot more difference than advance curve, IMHO. Jerry
