| | | Forums66 Topics128,154 Posts1,056,838 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 18 New Guy | | New Guy Joined: Nov 2014 Posts: 18 | Has anyone installed reusable silicone valve cover gasket on 235/261? Did they seal? Chasing down leaks.
Have used them on Cessnas and Volvos with success. | | | | | Joined: Nov 2014 Posts: 18 New Guy | | New Guy Joined: Nov 2014 Posts: 18 | Better question: What gasket WORKS well to seal stock 235/261 valve cover? Thanks | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I find 235 valve covers only leak when the wrong combo of parts are used causing too much oil to the top end.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | Well you can get the "BEST" gasket or felpro, (probably the best 2 options) but they will all be cork as far as I know. I don't believe any one is making the reusable silicone gaskets. I agree that would actually be the best idea, but the reality is, you can't get what someone ain't makin'. I have never really understood the recent/modern use of cork, it doesn't really even work that well. Back when these trucks were created, it was fine to build a machine that leaked oil all time. Now though, it isn't OK. And there are much better alternatives out there. I finally ended up using lots of permatex. I don't like it, and generally like to use never-seize on most gaskets. But these (all of the engine gaskets for that matter) don't seem to respond well to that method. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | "O'Reilly has 235 valve cover gaskets from Felpro in two thicknesses: 5/32" (PN: VS50189C) for $9 or 7/32" (PN: VS50190C) for $12."
I prefer the thicker one myself. If you take a level to your engine, you will find the front is higher than the back. I was getting oil dripping down the back for two reasons. One was if I set my valve cover on a flat surface, due to over-torquing, it wasn't flat. The other reason was my lack of permatex on the head surface. I like to use a good liberal coat of permatex on the head and NO permatex on the cover side. The thicker one just gives me a little more insurance. | | | | | Joined: Nov 2014 Posts: 18 New Guy | | New Guy Joined: Nov 2014 Posts: 18 | Thanks. I was wondering why NAPA listed 2 part numbers. I'll go with the -190 thicker one.
There'a a guy...most good stories start that way...in Tennessee that makes Cessna/Piper silicone gaskets. Says he can make a Stovebolt cover gasket. I'll try one and report back.
Thick gasket, Permatex on head, not cover. Thanks for the help.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | So.....a new project for that time when I haven't got any other things to do this winter? Get a nice new cork gasket. Seal it up with a few liberal coats of shellac. Call Renyolds or Smooth-On and have them send me out a couple pounds of silicone rubber or maybe urethane in about the shore 60A range. Pour a simple flat mold of plaster of Paris. Pull the cork master out and start making flexible rubber VC gaskets for a living.
Now----all you have to do is figure out how your going to keep them from squeezing out from under when you tighten down the tin.
dg
Denny G Sandwich, IL
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | the only leak I had was from over tightening the 4 bolts on my cover cork gasket.
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I wonder if a guy make some metal tabs to put into the gasket that would keep it from being over tightened? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | These fit under the bolts ...mr gasket set... But they have to be filed down to fit
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I glue the thicker cork gasket to a leveled valve cover (first, punch the over-tightening deformations in the valve cover rim upwards) and use no seal between cork gasket and head. Elongated flat washers were used with valve cover screws on my 54 and later 235/261 engines. The washers look like this but they are symmetrical (left/right are symmetrical and top/bottom are symmetrical). I'll go out to my freezer (garage) and look for one, if anyone is interested. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I need some of those. The tin itself just isn't enough. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Same here Glue gasket to the cover. on the head side I put a thin film of GP grease.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I thought we were talking about silicone gaskets? I was commenting on putting something in the mold when the gasket was poured to limit the amount of crush of the gasket. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I thought we were talking about silicone gaskets? I was commenting on putting something in the mold when the gasket was poured to limit the amount of crush of the gasket. I think people are responding to the first two posts - from the original poster? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Regardless of the type of gasket I have found this works great on my own engines. Avoid tightening the crap out of them the first go round. Drive it a week or two then retighten them. A little later after the gasket "sets". Then, on the next oil change, or two, just double check....you know, just a snug turn. Afterwards no leaking for me. Just my .02
Edit: I also do this on my Silverado and my wifes Buick. Every once in a while I snug the oil pan and tranny bolts. Its amazing what a quarter turn will do. The truck has 276,000 on it now and you can't find a drop of oil under it or on top of it.
| | | | | Joined: Jun 2012 Posts: 1,748 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,748 | Look a lot like the spring fingered tabs for a SB chev valve cover. Spreads the clamp force out a bit. Not much help when you run a 216 cover on a 235. Gasket wants to push out along the manifold side. So I glue it to the cover, and oil the head side. Seems to be working.
Steve H
| | | | | Joined: Nov 2014 Posts: 18 New Guy | | New Guy Joined: Nov 2014 Posts: 18 | Silicone gasket on order.
Where can I acquire a set of those four oblong cover mounting bolt washers tclederman shows for use to spread force along cover and gasket? | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | where did you find a silicone gasket? As far as I know you are the only person on earth that has been able to find one. whatever the case I prefer to glue the gasket to the head rather than the valve cover simply because it makes a little "dam" to help keep the oil inside rather than outside.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Silicone gasket on order.
Where can I acquire a set of those four oblong cover mounting bolt washers tclederman shows for use to spread force along cover and gasket? I do not know if the the screw holes are correct for 235/261. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Thanks Tim, we are gonna find out. | | | | | Joined: Feb 2004 Posts: 29,850 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | There are load spreaders available that are about 3" long, original equipment for Corvair valve covers. They fit and work well on Stovebolt and V8 valve covers. We used them regularly on race engines to prevent valve cover leaks. Most race parts suppliers like Jegs or Racer's Warehouse sell them. Jerry
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Did Gus’s repllly with the link to Mr.Gasket get lost in the shuffle. You ain’t gonna find any better ones to distribute the pressure over a large area than those. And they’re available at just about every place that sells auto parts. Here’s just a few off hand: Newegg, ebay, O’Reilly, Pace Performance, Jegs, Amazon, direct from Mr. Gasket or summit last to are the (cheapest). All under ten bucks. dg
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | Where can I acquire a set of those four oblong cover mounting bolt washers Fred, If you want the original look, the 6 cylinder ones are here: http://www.truckandcarshop.com/trucks47_59/t47_092.html
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Thanks, Tom
Those (54-08113) are the ones that I have found on 235/261 engines.
| | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | The cork gaskets come from the manufacturer bone dry. Oil absorption is required or them to seal properly. I glue mine to the valve cover while they are still dry, then apply enough oil, just shy of sloppy wet, and button everything up. As the cork absorbs the oil which is wiped on it, in addition to engine oil splashing around under the valve cover, it swells and improves the sealing action. That is why it is not necessary to really crank down the screws.
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Its funny what you learn here. Something as mundane as putting a new valve cover gasket can be a learning experience. All these years, I have put high temp permatex on the head and sealed the gasket to the head. Made sense to me back in the day, still makes sense today. Since the engine is not level front to back, about a 2 degree difference from front to back, with the front being higher, a riser such as the one you make from the gasket sealer will keep the oil from leaking out from under the gasket. Much less leakage on my engines. Very happy with the result, although I am sure it is bass ackwards from what everyone else does, I wouldn't have it any other way. But if there is some intelligent reason I shouldn't be doing it that way, I am all ears. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | If what you do works, stick with it.
There are often more than one way to solve a problem.
| | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | 3m spray adhesive is awesome for gaskets. Keeps them from moving or twisting during installation.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I never seal either side of the gasket and see no leaks. As I mentioned above, the 235's I have seen leak have the wrong combo of rocker parts, flooding the top end/gasket. I do not like it when I have to pull a valve cover where the gasket is glued to the cover. I always seem to catch and break the gasket on the rockers when I lift the cover off. As Tim said,"There are often more than one way to solve a problem".
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Nov 2014 Posts: 18 New Guy | | New Guy Joined: Nov 2014 Posts: 18 | a
| | | | | Joined: Feb 2004 Posts: 29,850 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | Where in Tennessee? I'd like to pay him a visit to see how he does that! I'm working on several projects that might need custom-made gaskets. Jerry
| | | | | Joined: Nov 2014 Posts: 18 New Guy | | New Guy Joined: Nov 2014 Posts: 18 | You asked: Where'd I get silicone stovebolt gasket? This is in NO way an endorsement or ad. I have ZERO connection with this business, other than our shop used their aircraft gaskets...I asked A&P mechanic about them and asked you guys about gaskets...I just fly them...with success thus far.
Gasket arrived, promptly, $29.10. Ordered Monday, arrived Thursday.
Looks professional quality and seems to fit contours of valve cover. Says to install DRY, NO lube. Reusable, soap washable.
I have not actually installed or leak checked. Not sure how to tack in place.
Real Gaskets Tennessee 2506 Stateline Road Elizabethton, TN (423) 543 6194
1937 TO 1962 Chevrolet STRAIGHT 6-CYL. 216, 235, 261 CID Part # CVC-3
They included a sample piece of fiberglass reinforced silicone gasket. I'm thinking CJ5 differential covers and BSA valve covers next.
Expect I'll no longer be only one on Earth to try these, eh? | | | | | Joined: Nov 2014 Posts: 18 New Guy | | New Guy Joined: Nov 2014 Posts: 18 | Hotrod Lincoln,
346 miles. US 64 Dellrose to Chattanooga, I-75 to I-40 Knoxville, I-81 to US 23 - Johnson City to Elizabethton.
Please let us know what you find there.
Born in Tennessee!
Fredthecat
| | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 |  ? Pictures please.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Feb 2004 Posts: 29,850 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | Thanks, Fred! I'm headed to Chattanooga on business tomorrow, but I won't be able to make it any further- - - -due in Memphis on Monday! I've racked up as much as 1500 miles in some weeks doing warranty claim inspections, and I'm supposed to be retired! Jerry
| | | | | Joined: Nov 2014 Posts: 18 New Guy | | New Guy Joined: Nov 2014 Posts: 18 | No idea how to post photos. Got tutorial? I expect a cell phone, cloud thingy etc would be needed...none here. 12 year old Wizard Grandson can do it.
Gasket "looks good" like something I would put on my motor...if it seals.
Jerry, when you do get to Elizabethton check them out for us and see what else they can make.
Greenest State in the Land of the Free. | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Check out the IT Short Bus forum for how to post photos Fred.
Dennis
40 Chevy 1/2 ton
