2 members (2 invisible), 84 guests, and 6 robots.
Topics128,266
Posts1,058,368
Members48,485
#1078149 01/09/2015 4:15 AM
Does anybody know what brake booster came on a 1968 c50, and where I can find a new one thanks
I'm not sure when Chevrolet went to the dual pot master cylinder, but if you have a single pot than you more that likely had the Hydrovac booster mounted on the frame rail. These are still available from NAPA or your local big truck parts store.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mine does have the single pot, but it is mounted on the firewall.
The M.C. is on the firewall,and you'll have a hydrovac located under the cab.,as Mike said. Check this out... abspowerbrake.com in an old topic,a member called them,and they fabbed an under-floor m.C./booster for his 2 ton!
Mo' Tater
3B Offline
Hy pipeliner78, Happy Birthday, you may have a Midland push through booster with a long stroke fairly small bore master cylinder mounted on the firewall. Unfortunately the middle to late sixties is a time of change for the hydraulic brake systems on medium and heavy duty Chevrolets and GMCs, it can be extremely frustrating trying to figure out which components the truck left the factory with, hope that helps.
Thanks everybody, but my master cylinder is bolted to the booster on the firewall just like on a smaller truck there is not a booster under the cab.
3B Offline
Hy pipeliner78, as I said in my first post from what you describe you have a Midland push through booster and master cylinder mounted on the firewall of the truck. I'll see if I can find some numbers, there should be a small tag on the booster clamp bolt with the Midland part number on it.
3B Offline
Hy Pipeliner78, as I said this age of truck is tricky to find the correct brake parts for and to give me the best chance of finding the correct parts I need a bit more information. Does your truck have a single or dual braking system (one or two brake lines connected to the master cylinder)? I did find a part number for the single brake system booster, GM p/n 3979525 = Napa p/n NBB 5479400 $381.60 + $56.00 core, hope that helps
Hey 3B it only has one line connected to the master cylinder. Thanks for the help.
