8 members (Chip O, MNSmith, Woodcmiami, LAROKE, Hotrod Lincoln, Southerntruck, gswbbc, 1 invisible),
113
Mod | | | Forums66 Topics128,032 Posts1,055,523 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 51 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 51 | I have a 50 one ton panel. Does any one make the step pad for these
1950 one ton panel, 1959 half ton apache
| | | | | Joined: Jan 2011 Posts: 51 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 51 | Goes on the running board
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jan 2011 Posts: 51 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 51 | On my running board it has one square hole where the pad goes, you think that would work
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The square hole is used on pickups and is just an open hole on panels and Suburbans. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Is there one hole or are there two holes for the running-board to bed splash-apron that is not needed on panel body trucks?
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Only the one on my 1/2 ton Suburban.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I'm lost here guys or I misunderstand. What does the holes that hold the splash apron do with bolting down the step pad, which the PO asked about, which is located under/at the door handle? ...been a long day. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I almost agree with you, Alvin. But, you assume the hole being referred-to is under the door handle (I also assume that it is somewhere under the door handle, on the step-surface of the running board). We do not know where the hole is in the original poster's truck's running board.
It would be nice to see a photo of the hole that is being referred-to by the original poster.
Otherwise, we are replying-blind.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Here is an image of a 47-55 running board. A picture is worth a thousand words/posts: the square hole (one square hole) is shown (the hole referred-to by Cletis and the original poster). The other three round holes are on the top edge/lip. Jim Carter sells 6 rubber plugs for filling those round bed-to-fender apron holes that is unneeded on a panel-body truck. My pickup is apart - is the square hole also used with the bed apron? To answer the original poster, the square hole is not under the door opening, so it would not be used for a step plate. The step plate requires drilling holes nearer the forward surface of the running board (the reproductions step plates that I have bought do not have a hole-drilling pattern/template). | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | I never noticed any holes on my 54 panel truck running boards. But then again, I really never looked. I can see that the upper three holes would be used for the pickup truck bed apron. But I can't see the lower single square hole, being used for the Step Plate. It's to far back on the board. Is the lower single square hole used for something else? Other than the anti-slip step plate.
| | | | | Joined: Jan 2011 Posts: 51 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 51 | the hole is about a foot away from the door towards the rear, strange that a hole would be on the running board and not be used. I would send a pic but not sure how
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Perhaps not weird when you consider a punch press and dies set-up for production efficiencies. In the general scheme of things that small hole may not have been worth additional or different tooling. Production levels for many of the AD years exceeded 300,000 units. Here is the step install directions which had not worn the years well, the measurements fortunately could be saved. https://www.flickr.com/photos/advance-design_parts_co/16023979479/in/set-72157631868452754 | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Thanks Brad and Tim for your contribution. I have got pickup running boards on my panel and plugged the holes. I was planning to check the assembly manual to see that the lone square hole is for......At first glance I thought it may be to attach a rod to hold a spare tire on a pickup but I've not had the daylight hours to check in to stuff. Heck, I'm just always curious!! | | | | | Joined: Jan 2011 Posts: 51 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 51 |
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | tdplbg - your link does not work
| | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Correct: http://s374.photobucket.com/user/Terrance_Davidson/library/ Incorrect: http://http://s374.photobucket.com/user/Terrance_Davidson/library/ When you click on chain link icon on the Posting a message form/page. Do not remove blue highlight on the http:// string. That is why your getting duplicate http:// strings. pics of panelNice panel Looks like it is a 1 tonner. | | | | | Joined: Jan 2011 Posts: 51 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 51 |
