| | | Forums66 Topics128,108 Posts1,056,227 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I saw this at Lowes yesterday, it appears it might actually be an improvement over Stabil. Just google "startron" | | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | From a cursory look at their public catalog page they make way too many exaggerated claims. Their scientific statements/claims are at the least misleading and some are inaccurate. I also question the ability of an enzyme to inhibit formation of gum and varnish.
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | It looks like their main ingredient comes out of the north end of a southbound bull. At least a few of their other products appear to be repackaged examples of other companies' products. Their moisture absorber has exactly the same size and shape container as "Damp-Rid", and I'll bet there's a healthy markup involved in the relabeling process. Ditto for most of the other "boat care" products they sell. Is P.T. Barnum still alive? Jerry
| | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | With the mileage these trucks get I'm amazed we need to think about a fuel treatment. I've never used a gas additive, I do run an additive with my diesel.
Lincoln, love the metaphors...
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I was actually thinking about my mustang, which doesn't get driven too much. I did a lot of looking at the reviews, and there were a few other discussion forums with this as a topic. It seems all the comments were positive, whatever that means. I was just wondering if anyone else had heard of it. | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | Is sea-foam comparable? My neighbor swears by that stuff.
| | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | Sea-Foam actually works, but mostly as a fuel stabilizer. I use it in all the small engines around the farm that only get run intermittently, and in the motorcycles my son and I run. It prevents at least most of the alcohol-additive nightmares untreated gasoline causes, especially in engines that get stored over the winter. Like any other fuel or oil additive, it's not a cure-all, but it seems to work well for its primary purpose of keeping gasoline from going stale. Jerry
| | | | | Joined: Feb 2000 Posts: 5,216 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,216 | I don't use any additives and my truck can set for months at a time during winter, dad's race car sets even longer. Best bet for long term storage is using 100% gasoline. We are lucky to have a couple of stations in the area that carry pure premium 91 octane gasoline. I fill up with it mid October, which can carry me over till spring if I don't drive to much. My truck is in a garage that stays 45 to 50 degrees, so that may account for some of the long term storage with out problems. I am also using two W-1 carbs, which are cast iron, so no worries about aluminum or pot metal damage.
Joe | | | | | Joined: Jan 2014 Posts: 3,687 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,687 | Sea-Foam actually works, but mostly as a fuel stabilizer. I use it in all the small engines around the farm that only get run intermittently, and in the motorcycles my son and I run. It prevents at least most of the alcohol-additive nightmares untreated gasoline causes, especially in engines that get stored over the winter. Like any other fuel or oil additive, it's not a cure-all, but it seems to work well for its primary purpose of keeping gasoline from going stale. Jerry Does Mystery Oil have similar fuel stabilizing properties to Sea Foam? A quick internet search provides divergent opinions. I have some MMO, but do not have a can of sea foam, and do have need to treat some gas that might sit a while.
1951 3100
| | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | I don't know how it would. I know it actually decreases lubricity as a diesel additive.
| | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | I've used MMO as a fogging oil to treat sticky valve guides, etc, but never as a fuel stabilizer. The best penetrant for valve guide deposits is KROIL, in my decidedly biased opinion. "Your mileage may vary!" Jerry
