0 members (),
164
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | In my 66 Suburban, I have the 292 motor with the smog pump and system. I need to rebuild my carburetor, but I am not sure if I have the correct carb or not. According to the 66 Shop Manual, there is a different carb for the non smog motor (7024009) and for the smog motor (7036009). My carb does not have a metal tag on it with the part number on it. Is there a way to identify my carb and does anyone know what the difference is between the 2 carbs, as far as a rebuild kit is concerned? Thank you for your help. | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | I had a carb decoding question once and fellow Stovebolter CARBKING was very helpful. Currently he is not set up to get PMs but here's a LINK to his CONTACT PAGE so you can ask him for help. I think he will know. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I agree Carb king will have the answer. He also sells kits. They probably use the same kit. The difference is in the jeting & carb kits don't have new jets anymore. It is probably a California truck. The other states didn't use that system until 68. Or the engine was replaced with a newer engine at one time. Is it a Roch. model B carb or a Monojet. If it is a MJ the number is stamed on the side of the bowl section.
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2000 Posts: 5,228 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,228 | According to my Delco Carburetor catalog, the 7024009 fits 1964-1966 292 truck engines, the 7036009 fits 1966 A.I.R. 292 truck only. Bulletin #9C-3003T
Differences:
#7024009 ------- #7036009
7008672 --------- 7008671 --- main jet 7025554 --------- 7025554 --- power valve 7002896 --------- 7002896 --- power piston spring 701002 ----------- 7010002 --- power piston assembly
{ #7027093, intake air bleed valve assembly (A.I.R.) } only
It appears all the other parts are the same, jetting is one size leaner on the A.I.R. carb and possibly the power piston assembly, the catalog could have a typo on the numbers.
Over haul kit number listed (November 1971) #7016456
Hope this helps.
Joe
| | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | Thanks for your help everyone. Obviously there is a difference inside between the two, now I just have to figure out if I have the one I'm supposed to have. | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | There is a shop in town that does old carbs. Ricks carburetor in el Canon. I can't remember the number but he has helped a few of my buddies with their oe carbed caddies and what not.
| | | | | Joined: Feb 2000 Posts: 5,228 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,228 | Both will work for what you have, like I said, the Delco manual only lists the metering jet as being different, all the body parts and other internals are the same. Go with the best looking and most complete and you should be just fine.
joe
