| | | Forums66 Topics128,026 Posts1,055,409 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 4 New Guy | | New Guy Joined: Jan 2015 Posts: 4 | Hello, My name is Pat and I bought a 64 C-20 truck that was used as work truck. It had a utility body on it that was rusted beyond repair. My son and I completely tore it down to the frame. The cab is repairable but I got lucky and found a complete cab with doors and hood off of a 65 C60 farm truck for $100 bucks. It needs new floor pans cause it looks like the cab mounting bolts are in different spots. I was really looking for a 6 foot box. I had planned on putting front disc brakes and power steering. I had a friend that had a 76 1/2 ton truck. took the front suspension from it and cleaned it all up. I replaced all the bushings, calipers, hoses, rotors and pads. I found a 64 short bed in a junk yard. I got it for $300 bucks. I stripped it down and had it powder coated. I installed the front suspension from the 76. Surprisingly, it bolted right up with no mods. Now I'm working on the steering. I got all new tie rods and center link which are bigger than the original. I know you have to use spacers to install the gear box. Has anyone done this to theirs? I'm trying to do this with as little modification as possible. Any body have any tips? I'll post pics soon.
| | | | | Joined: Dec 2014 Posts: 72 Shop Shark | | Shop Shark Joined: Dec 2014 Posts: 72 | Welcome aboard! I have no knowledge as far as swapping parts, but sounds like you have a neat planning coming. Looking forward to pictures. TJ | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Pager,
The 63-66 cab mount different from the earlier models. The mounts on the frame are different. Contact tony at 4-5-6- Chevy he can guide you.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....and welcome to the Bolt, Pager! | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Welcome to the pages and to the MD and VA group. | | |
