5 members (37 GC, Dusty53, sron48, Vice-Grip, Otto Skorzeny), 130 guests, and 0 robots.
Topics128,114
Posts1,056,613
Members48,450
#1076426 01/01/2015 12:12 AM
My '52 3100 has the original 216 along with the original glass bowl fuel pump. I noticed the pump was leaking today, pulled it apart, and as I suspected the diaphragm is cracked. I have searched for a rebuild kit with no luck. I did a search here and found this question asked before, but never saw a sufficient answer. Can anyone point me in the right direction for parts to rebuild this pump?
'52 Chevy 1/2 ton running original gear
Z
Z Offline
Theres a place called zenith Nixon in Omaha ne that used to be the place to find anything related to old carbs,might give them a try.
402-341-1167
I know this listing is for a F**d but it is the same as Chev. LINK
My Blog
Jim Carter also sells the kits.
Hey Guys--Go to your local GM dealer and give the Parts man the Part number and lo and behold 1 day later I had a new pump. The only difference was it had a metal top cover instead of a glass one.Works perfect. Cost about $65.00. The local Napa parts store also had one for about $75.00.
Hope this helps, Stan
The only problem with the metal top replacement pump is that it does mot have any filtration inside like the glass bowl pumps. Without the internal screen there is nothing protecting the check valves.
With that style pump I would recommend putting a filter before the pump.
My Blog
8
8 Offline
Curt Warren
Salt Lake City
1948 1.5ton Loadmaster
http://photobucket.com/48loadmaster
Thanks for all the replies. I saw a new fuel pump from Napa and other folks. But, I wanted to keep the look of the original glass bowl.
I ordered the diagphram that 'Pre68Dave turned me onto. It looks the same as what I need. If not, I will order the Jim Carter kit....although pricy.
If it was my pump I would be replacing the check valves also.
