0 members (),
170
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 791 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 791 | What was the stock placement for the rear view mirror on the center division bar in the A.D. truck? My 1948 Chevy 1/2 ton has the 4-hole divider, and the mirror is attached with a small bracket. It is not screwed into a 5th hole that some of the divider bars have. I have seen the rear view mirrors fastened to either the top hole closest to the headliner, as well as the hole 2nd from the top. How were they positioned when they left the assembly line? Any evidence is always welcomed.
Thanks.
LUKE
P.S. Merry Christmas everyone! | | | | | Joined: Feb 2012 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 44 | I would like to know that too also what is that fifth little threaded hole for. mine has a set screw in it | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Luke,
This is one of those that won't be a "how it left the factory" items. The mirror is an accessory item not a factory option, the best resource will be the relevant year accessory installation manual. | | | | | Joined: Jun 2009 Posts: 791 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 791 | Does placement then really just boil down to owner preference? | | | | | Joined: Jun 2009 Posts: 791 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 791 | Based on the excellent detailed info. + photos provided by Brad Allen, I must conclude that I have the incorrect center divider trim piece in my 1948 Chevy 1/2 ton. A p.o. must have needed one, and felt that this would work. In the 1947-1954 Factory Assembly Manual, Section 1, Sheet 41.02, the Division Reinforcement to upper rail & instrument panel clearly shows the 5th hole that matches the divider trim piece. Thank you!
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Do you have the 5th hole under the trim?
| | | | | Joined: Feb 2012 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 44 | on my 49 the window frame has the threaded hole and the trim piece has a non threaded hole | | | | | Joined: Jun 2009 Posts: 791 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 791 | Gus--
Thanks for the heads-up. I made the assumption...based on the diagram in the FAM. I am away for the weekend and will check 1st part of next week. My truck is up on blocks, zipped in its Car Jacket, in cold storage (pole barn) sleeping for the winter. I will report back in with my findings.
LUKE | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | My 50 has a threaded hole for the mirror, I remember a past thread where Denny posted that his 50 did not.
may be one of those quirky assembly plant things. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 |
Denny G Sandwich, IL
| | | | | Joined: Jun 2009 Posts: 791 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 791 | As suspected, my center divide DOES have the 5th threaded hole under the trim piece for the mirror. http://s160.photobucket.com/user/st...ield%20center%20divide?sort=3&page=1My plan now is to add a 5th hole on my divider trim piece using the drill press; can someone verify the proper hole size (9/32")? I will also need to drill out my rubber seal as it is solid, blocking access beyond the threaded hole. Is there a rubber seal made with the 5th hole for the mirror? I have completely ignored this 5th threaded hole when doing any previous work in this area!
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Do you have to drill the hole in the vertical rubber piece???? As I remember the mirror was held on by a THIN nut behind the metal trim with another bolt on the inside.....but I may be wrong or the ones I've seen are wrong? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | You should not need to drill your gasket Although steel gasket comes with a dimple in that area ...pic... ...old gasket... ...old gasket... Just thread the stem of the mirror in | | | | | Joined: Jun 2009 Posts: 791 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 791 | Men...mission accomplished! I ended up drilling a 5/16" hole in the divider trim piece. As suggested, I did not need to hog-out the rubber gasket. I threaded the mirror stem into the threaded hole and used the jam-nut to secure it in place. There is no noticeable wobble; will test her out when April arrives here in Michigan! http://s160.photobucket.com/user/st...nder_zps637f53b1.jpg.html?sort=3&o=0Thanks for all the good advice--as usual. There is always something new to learn about these old, lovable trucks of ours!  Happy New Year to all!  | | |
