8 members (JoergK., MickeyP, EchoBravoSierra, FAST55, Forty9, Joe H, 55shaker, 1 invisible),
43
Mod | | | Forums66 Topics128,175 Posts1,057,118 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | What are the best options for the lines going to and from the filter. Today I went to napa and was not impressed with their option of high pressure hose. Is ridgid tubing an option, I don't mind bending and flaring tubing. If all else fails I just may take the filter off. Thoughts? Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | They look nice to me. What pressure, maybe 300psi. Napa wanted to use real high pressure line. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | I am not sure how far you are to a hose shop but I used a local hose shop , I moved my canister so the originals would not work anyway. I went to the local hose shop and gave them the measurements and I walked out a few minutes more with my set up. They did mine in stainless steel braded and I am Happy with the set up. oil lines 1 oil lines 2
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | I would recommend the rubber. The braided lines looked good too.I have done the trick with the metal lines and it generally works. It has been suggested before to put a Lockheed loop?? in the metal lines to fight the vibration. This is just making a coil in the line.
I was convinced that the factory style rubber lines were best when I smogged an intersection with smoke from an oil leak hitting the manifold.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | I took the easy way out & used regular rubber fuel line & barbed fittings. <CLICK>
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I used metal lines and thought I did a great job. The first time I tried to use the drain plug I found out why flexible lines would have been better! | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | I've put approx. 8500 miles on a 216 w/rubber lines feeding the bypass oil canister without a problem (knock on wood). Got the rubber lines as a kit from one of the aftermarket suppliers many use on this board. Kit had everything needed to connect from block to canister and back.
Dave | | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | Learn something every day if you pay attention. Lockheed loop. Love it. Ridged lines need to flex. Heat, cool, and shake will destroy them. How did I learn? Put three gallons of gas in your boot and on top of a hot engine at 60 miles per hour. That will get your attention! It will also keep you from work. And no one will stop for scooter trash with one boot during a busy commute. I should have known. We use them all the time for Aircraft hydraulics. Dummy, dummy. I never knew that loop had a name Thanks!
Steve H
| | | | | Joined: Mar 2010 Posts: 10,307 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,307 | How many tractors with bypass filters do you suppose Ford made? Millions? They all came with hard lines. Since the filters are attached rigidly to the engine, there is no movement to cause metal fatigue. Same deal with manifold mounted filters on Chevrolets. My belief is that, since Chevrolet trucks didn't come with the filter, it was up to the filter manufacturers (Fram etc) to come up with a way to plumb the lines for a number of different configurations of engines. Soft lines would have been the most forgiving for minor variations between engines encountered. Steel lines would have been more economical, so it wasn't about saving a few pennies. Just my 2 cents. Carl
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | How many tractors with bypass filters do you suppose Ford made? Millions? They all came with hard lines. Since the filters are attached rigidly to the engine, there is no movement to cause metal fatigue. Same deal with manifold mounted filters on Chevrolets. My belief is that, since Chevrolet trucks didn't come with the filter, it was up to the filter manufacturers (Fram etc) to come up with a way to plumb the lines for a number of different configurations of engines. Soft lines would have been the most forgiving for minor variations between engines encountered. Steel lines would have been more economical, so it wasn't about saving a few pennies. Just my 2 cents. Carl Carl, You have made a good point. So you think the rubber line method of production was more for the flexibility in production and application than the need for flexibility in the connection? Anyone have some good images of your hard line solutions? Paul | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | I used copper lines and after a few years they work hardened and broke . I believe any style of flex line is a better option. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The by-pass oil filter lines on GMCs are copper - for the filter units that bolt to the block.
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Anyone have some good images of your hard line solutions?
Paul I've never had an issue with hard lines and think it looks cleaner: 1.2.3.Merry Christmas Bolters!
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Curt B. You have sold me. What kind of tube did you use and did you use flare or compression fittings? Dave
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Dave,
I've always used 3/16" prefab brake lines utilizing the existing flare on one end and a compression fitting on the end I cut to length.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Curt, do you use the original fitting that restricts the oil flow? | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I was told the restriction was in the filter canister, is that correct? 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
Steve H
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The stand pipe in the center of the filter housing has a small hole in the side of it that the oil passes through.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | One of the pictures shows a spin on | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Guess I should have mentioned that spin on filter head is an Amsoil bypass unit which has a restrictor plug built in. (1/16" diameter)
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Thanks, Curt
What is the Amsoil part number?
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Thanks, Curt
What is the Amsoil part number? Part number is BK303. Here's a link which shows the restrictor plug.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | When plumbing hard lines for various applications, I've always included a 360 degree vibration loop somewhere in the line if possible. Bending the line all the way around a big socket (1 1/4" or so) clamped in a vise makes a good looking vibration loop without collapsing the tubing. Jerry
