| | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 176 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 176 | Sorry, there aren't any pics yet, but there will be! I'm really trolling for some info. I spent the day combing through the local junkyard looking for beds, but coming home only with ideas. I found a bed with a really cool stamped outer edge, looks like two half circles running down the side. I want to duplicate this look on my bed as I think it would look better than flat box tubing. I'm also looking for stamped fenders with the rolled edge that are heavy duty and wide enough to cover 20" duallies. Anyone have any good pics of old headache racks off of an old logging truck? Last but not least does anyone make mudflaps with the old GMC script on them? I'm abviously still trying to source on my own just figured I'd ask the people who have been looking for years? The bed will be 9'-10' long,I assume someone is making bed strips that long? | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I like to look for flatbeds/stakebeds for sale on ebay for ideas. Also most towns have truck body dealers with all kinds of set ups for various needs. Our local one has a big yard with all kinds of take-off bodies from previous rebuilds, fun to look at for ideas. Best of luck | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Hey Straightjacket, I like the look of your COE, keep us up to date on what you come up with on the back half. That is one cool looking truck. Steve 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Mar 2013 Posts: 176 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 176 | #43 - Ya, I'm looking everywhere at idea beds, just keep hoping I'll see the perfect one and bolt it on for $100. Ya right!
ss - Thanks and I'll post pics as I go. Need to put some parts that I have in-stock on first then off to the metal shop to pick up supplies. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Our illustrious leader, John Milliman, built a nice wooden bed for one of his rigs. Maybe a search by you can locate it or perhaps another member or John will post a link.
Drew
| | | | | Joined: Feb 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 190 | My brother and I made my bed, works well and Iam pleased with it. Good luck with your's. | | | | | Joined: Mar 2013 Posts: 176 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 176 | Pretty cool! I checked out your gallery page. I had thought about a bevertail bed but haven't decided yet. What type of stack are you using and where did you get it? I'm a little worried about the speed of the truck as well and had planned on modernizing it down the road. The more I work on it the less I want to cut it up? | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | If by "looks like two half-circles running down the side" are you referring to a top and a bottom reinforcement rib on the side rail?(rubrail) If you are and it is a factory built body it could be a Knapheide brand. One of their models, std HD model, has that feature. It could have a wood, smooth steel or tradplate floor. It would have formed crossmembers. There are various bulkheads available to fit them. As for fenders to fit duals I would look to a semi-trailer dealer or a truck body distributor for drive axle fenders. | | | | | Joined: Mar 2013 Posts: 176 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 176 | 53 - That sounds like the bed I saw. It was a wood bed. It looked to hard to change into what I want, but gave me some good ideas. | | | | | Joined: Mar 2013 Posts: 176 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 176 | Rummaging through a local salvage yard I came across a candidate for my truck. It appears to be very straight. The wood is long gone, but it has the stamped sides that I like. I think this style bed will fit in with the Art Deco cab. I was going to make my own bed but I can't even buy metal for what this cost. I may change it up a bit later,but for now it looks like it will just bolt on. It should be delivered today.I will post more pics as it gets torn down and cleaned up. | | | | | Joined: Mar 2013 Posts: 176 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 176 | I have pics of the new donor truck/bed in my signature now. Was able to pick up the bed for $300. All of the metal is good and usable. It sets on the truck pretty good as is, but I'm thinking about possibly shortening and or narrowing for a different look. | | | | | Joined: Mar 2013 Posts: 176 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 176 | Looking at the bed while paint is drying on other parts I've noticed a couple of issues. The bed has a wider gap (between cross supports) where the rear tires are supposed to be centered. I'll have to slide the bed back on the frame rails to make this work. The bed is already hanging over the rear of the frame,so I will have to cut a section out from behind the rear wheels and put it back in, in-front of the wheels to make it back up. Not quite sure how this is all going to pan out with stake pockets and such? | | |
