6 members (ndkid275, Southerntruck, Gray_Ghost, Bill Hanlon, Otto Skorzeny, JW51), 81 guests, and 2 robots.
Topics128,133
Posts1,056,396
Members48,441
#1072560 12/10/2014 3:47 AM
7
7 Offline
In my 1950 3100 Chevrolet, does anyone know if the gas tank was painted the same as the steering column in that light brown color.
Thanks for any info.
1950 Chevrolet 1300 - Canadian Built
This truck is now for sale (9/2016)
All Original
More pix in Bolt Bucket
7998 #1072562 12/10/2014 3:52 AM
gas tanks were galvanized color, not painted
Flxible #1072863 12/11/2014 10:51 PM
7
7 Offline
Thanks for info.
All Original
7998 #1073670 12/16/2014 8:34 PM
Gas tank in mine was the color of the interior paint. I have no reason to believe the interior was ever repainted after original. It appeared as though it were painted in the truck.
7998 #1073731 12/17/2014 1:52 AM
Same here Eric, I was fortunate enough to have talked with the
people that maintained this truck and new it from when it was
bought new. The out side was sprayed a real rough red because
it was used as a small town fire truck, but the interior was
never touched. The tank had a light dusting of the interior
color as though it had already been installed at the time it
went thru the paint shop. There was even Mariner Blue over
spray on the upper part of the outer filler neck. I'm guessing
that the grommet was installed some where down the line and
the over spray blew thru the opening.
DG
Denny G
Sandwich, IL
7998 #1073734 12/17/2014 1:57 AM
My 54/55 Chevrolet and GMC regular cab trucks had the original paint on the outer-side of the gas tanks and it looks to me that they were painted in-place when the interior was painted.
As I recall, the hold-on straps were not painted (but I am not sure about that).
7998 #1073735 12/17/2014 2:02 AM
My tank had interior color on the top portion of the tank only. This included the straps. This was my grandfather's truck so I believe it to be fairly original. It was originally a Bell Telephone truck and when I pulled the tank I found a scheduling book with the jobs they were scheduled to do that day laying in there so I presume the tank was never removed.
Good Luck
36 Chevy 1.5 ton - rusting away
52 Chevy 3100 - in progress
72 Chevy K20 - DD
PANTS UP DON'T LOOT! PANTS UP DON'T LOOT!
NEVER watch another man eat a banana.
7998 #1073744 12/17/2014 2:34 AM
Does this mean originally they didn't paint behind the gas tanks??
7998 #1073751 12/17/2014 2:59 AM
My 54 had the tank sitting behind the seat when painted and the strap stood up and hooked under the opening below the rear window. So the tank is the light blue same as the interior on the two tone blue interior. Behind the tank is not painted, and the underside of the tank straps are painted. When they were pulled down to hold the tank, the exposed part of the straps are unpainted. Again, this was the deluxe cab option in 54 with the two tone blue interior.
7998 #1075109 12/24/2014 4:28 AM
Another vote for the tank painted interior color for a 1950 3100. Here is a twist though, a green fill spout on a blue pickup with the original tank. You can't see the green paint from the outside because the factory masked the end of the spout. I have also seen the spout painted the original color.
Dustin
7998 #1075486 12/26/2014 6:45 PM
my truck had overspray on my gas tank, too
Indy wink
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
