1 members (78buckshot),
112
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,136 Posts1,056,425 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2014 Posts: 77 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 77 | In my 1950 3100 Chevrolet, does anyone know if the gas tank was painted the same as the steering column in that light brown color. Thanks for any info. John | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | gas tanks were galvanized color, not painted
Bill | | | | | Joined: Sep 2014 Posts: 77 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 77 | | | | | | Joined: Dec 2006 Posts: 113 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 113 | Gas tank in mine was the color of the interior paint. I have no reason to believe the interior was ever repainted after original. It appeared as though it were painted in the truck. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Same here Eric, I was fortunate enough to have talked with the people that maintained this truck and new it from when it was bought new. The out side was sprayed a real rough red because it was used as a small town fire truck, but the interior was never touched. The tank had a light dusting of the interior color as though it had already been installed at the time it went thru the paint shop. There was even Mariner Blue over spray on the upper part of the outer filler neck. I'm guessing that the grommet was installed some where down the line and the over spray blew thru the opening.
DG
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | My 54/55 Chevrolet and GMC regular cab trucks had the original paint on the outer-side of the gas tanks and it looks to me that they were painted in-place when the interior was painted.
As I recall, the hold-on straps were not painted (but I am not sure about that).
| | | | | Joined: Apr 2013 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 165 | My tank had interior color on the top portion of the tank only. This included the straps. This was my grandfather's truck so I believe it to be fairly original. It was originally a Bell Telephone truck and when I pulled the tank I found a scheduling book with the jobs they were scheduled to do that day laying in there so I presume the tank was never removed.
Good Luck
36 Chevy 1.5 ton - rusting away 52 Chevy 3100 - in progress 72 Chevy K20 - DD
PANTS UP DON'T LOOT! PANTS UP DON'T LOOT!
NEVER watch another man eat a banana.
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Does this mean originally they didn't paint behind the gas tanks?? John | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | My 54 had the tank sitting behind the seat when painted and the strap stood up and hooked under the opening below the rear window. So the tank is the light blue same as the interior on the two tone blue interior. Behind the tank is not painted, and the underside of the tank straps are painted. When they were pulled down to hold the tank, the exposed part of the straps are unpainted. Again, this was the deluxe cab option in 54 with the two tone blue interior. | | | | | Joined: Dec 2014 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 36 | Another vote for the tank painted interior color for a 1950 3100. Here is a twist though, a green fill spout on a blue pickup with the original tank. You can't see the green paint from the outside because the factory masked the end of the spout. I have also seen the spout painted the original color. Dustin | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | my truck had overspray on my gas tank, too Indy
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | |
