Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (3B, 1955 1 Series), 36 guests, and 2 robots.
Topics128,009
Posts1,055,296
Members48,419
#1074742 12/22/2014 8:32 AM
hi all, ive tryed to determine what speed i was at long ago,(creative driving days lol).i had 28" tires,323 gears, and sm420 trans.if some one could help my mystery would be most appreciated.my computer doesnt like to help much here.ill be sendin in pics of my 52 drw 3800 soon. good luck all on your projects. oh yeah on last night running i was turning 6,000
ODSS Lawman
ODSS Lawman
You can use some tools found in the Tech Tips. Using a Ratio Calculator
With the info you provided, 6000 RPM, 3.23 rear end and SM420 and 28" tires you were going 154 mph.
I hope your brakes are good!
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
I always knew these trucks could really move!
1951 1 Ton Completed
Maybe the tachometer is set for a 4 cylinder or 6 cylinder. 6000 seems way too high.
Rather than make a guess at it, does someone you know have a GPS or a smartphone that you can go for a drive with?
I got the same 154 MPH that SWEET did. I'm assuming that both the RPM and gear ratio are off.
My 46 GMC on Photobucket
Getting 6K from a stovebolt engine is about as likely as finding a chicken with lips. 3500 would be pushing things. What engine are you running, and what brand of tachometer?
The simplest way to get an accurate speed reading is to use a Garmin or TomTom GPS and compare the satellite info to your speedometer, then either adjust the speedometer drive gear teeth up or down or get a ratio-change box from a speedomerer shop.
wots50 #1074831 12/22/2014 10:16 PM
3800 with dual rear wheels and a sm420, motor turning 6,000?
Sounds like something is haywire here, not saying it can't be done but I'd sure be worried about shrapnel.
wots50 #1074833 12/22/2014 10:20 PM
Would it even go that fast, if you dropped it out of an airplane?
Just wondering.
Brian
Brian
1955.2 3100 Truck
wots50 #1074841 12/22/2014 10:48 PM
Thanks for fast responce,that was'nt 3800 or early bolt motor.62 1/2 ton panel with olds rear,punched out 292 with lots of miles.poor brakes,bad tires.but good enough to keep the pole with 12 cops in tow.45 mniles later i lost em.but had 3 worrents out by then.
wots50 #1074843 12/22/2014 10:51 PM
oh yeah it was cheep electronic tach.motor only seen top rpms for a secont until that last night.with heavy oil it worked but last night was last time it ran,down 3 1/2 quarts of oil
wots50 #1074852 12/22/2014 11:32 PM
I think this post should go to the greasy spoon......serves no purpose here.
I believe the tires would have come off of the wheels at 154 MPH.
Too bad he's on the left coast- - - - -if he could come and talk to my garden for a while next spring, I could save a bundle on fertilizer!
grin
Allen
1974 Stingray Corvette
Hotrod,
do you mean to tell me that chickens don't have lips? That just wrecked my christmas vacation. :-)
Originally Posted by ndkid275
Hotrod, do you mean to tell me that chickens don't have lips?
That quote is from the chorus of a silly little song from the 1970's, back when Rowan and Martin's "Laugh-In" was the most popular show on TV.
"Does a chicken have lips?
Does a rattlesnake have hips?
Can an elephant make a living blowing bubbles through his nose?
If your goldfish grows hair, and starts sleeping in your chair- - - -
Just blow in his ear- - - -he'll follow you anywhere!"
I've searched just about every song lyric database I can find, and I can't come up with an audio track of that one. It's not on You Tube, doggone it! Funny song!
Edit: Found it!
LOL!
