0 members (), 137 guests, and 0 robots.
Topics128,102
Posts1,056,184
Members48,436
#1074158 12/19/2014 3:51 AM
Where is a good source for brake parts for my 48 2 ton? Looking for a master cylinder kit to start with.
[URL=http://s2.photobucket.com/user/sdkid/media/48%20Chevy/GetAttachment2.jpg.html][IMG]http://i2.photobucket.com/albums/y30/sdkid/48%20Chevy/GetAttachment2.jpg[/IMG][/URL]
Chris
"48 Chevy Loadmaster
2- '68 C10
70 C-10
sdkid #1074233 12/19/2014 2:42 PM
sdkid;
NAPA auto parts should have everything you need, if it is not in stock they can get it in a couple of days. The wheel cylinder rebuild kit for the rear wheels (1 1/2" bore) is #37,I just picked up wheel cylinder kits and a master cylinder kit from them for 1940 1 1/2 ton.
John G
1942 G5106 1.5-ton Chevy cargo dump Gallery page
Old Dominion Stovebolt Society
T/Sgt. Gott (28 years of service with the USPP)
1940 Chevy G506 4112 cargo dump
1942 Diamond T G509 969A 4 ton wrecker
1942 Ward LaFrance G116 series 2 10 ton wrecker
1944 Ward LaFrance G116 series 5 10 ton wrecker
1931 Ford AA with a WEAVER crane
1944 Sterling HC 165 tractor
1944 Autocar U7144T w/ 10 ton trailer
sdkid #1074306 12/19/2014 8:30 PM
My expierence with self-rebuild of brake parts on these old trucks, went terribly bad. I rebuilt some of the wheel cylinders and the MC myself. I wound up having to remove all those big wheels and tires, drums and axels twice. The MC and the WC's failed. I bought new wheel cyls and a new master cylinder. Now, no problems. I got them all at a reasonable price at NAPA and Rockauto. This was a 57 GMC 2 1/2 ton with 8 wheel cylinders.
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
sdkid #1074315 12/19/2014 8:51 PM
I too have had reasonably good luck with NAPA. I had to do most of the part number research myself but they wound up having access to new wheel cylinders both front & rear for my '46 2Ton. I can't attest to the master cylinder kits, though, as I was lucky enough not to need one.
Pete P.
Harborcreek, Penna.
sdkid #1074384 12/20/2014 4:20 AM
I didnt think it could be that easy. I will check with my NAPA store. Thanks for all the replies.
Chris
2- '68 C10
70 C-10
sdkid #1074442 12/20/2014 2:56 PM
Make certain that you inspect the cylinder bore for rust pitting before you spend money on a rebuild kit. Years of non-use tends to create a lot of condensation in the MC cinder wall. Pitting will result in leaks.
Lots more pictures
sdkid #1074447 12/20/2014 3:45 PM
HI ,Napa online can be a problem child ,Here is a trick for the Napa to find parts for your truck .
1 - put in search box master cylinder
2 - do not put any info to what kind of vehicle your looking for click search .
3- now it will be a new page showing master cylinders now look for medium to heavy duty trucks in the menu on the left ,then the make ,and then the year .
Now you should see the master cylinder listed for your truck it should say one and a quarter inch bore same as my 48 2 ton Part Number: UP 33 $20.70 /ea rebuild kit only available
wheel cyl. front Part Number: UP 3406 31.95 /ea
kit Part Number: UP 8 $14.85 /ea
Wheel Cylinder - Rear Part Number: UP 3677 102.60 /ea
kit Part Number: UP 37 $15.75 /ea
RAYBESTOS Part # MC9220 master cyl rockauto.com $44 and change plus shipping
DORMAN Part # M9220 master cyl. rockauto.com $80.79
rockauto.com has the the wheel cyl's much cheaper
Just call me I can give you more info .865 274 3793 EST Florida .,I'm up late paul
I changed mine to a one and a quarter inch bore dual circuit master cyl. a 7" dual diaphragm booster ,great brakes but it needs a vacuum holding tank and check valve put into the system .
Hope this helps
Paul N.
1948 Chevy 2 ton flatbed ex fire truck , and various motorcycles .
