0 members (),
133
Mod | | | Forums66 Topics128,157 Posts1,056,876 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2014 Posts: 10 'Bolter | | 'Bolter Joined: Apr 2014 Posts: 10 | Where is a good source for brake parts for my 48 2 ton? Looking for a master cylinder kit to start with.
[URL=http://s2.photobucket.com/user/sdkid/media/48%20Chevy/GetAttachment2.jpg.html][IMG]http://i2.photobucket.com/albums/y30/sdkid/48%20Chevy/GetAttachment2.jpg[/IMG][/URL]
Chris
"48 Chevy Loadmaster 2- '68 C10 70 C-10
| | | | | Joined: Aug 2004 Posts: 242 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 242 | sdkid;
NAPA auto parts should have everything you need, if it is not in stock they can get it in a couple of days. The wheel cylinder rebuild kit for the rear wheels (1 1/2" bore) is #37,I just picked up wheel cylinder kits and a master cylinder kit from them for 1940 1 1/2 ton.
John G 1942 G5106 1.5-ton Chevy cargo dump Gallery pageOld Dominion Stovebolt Society T/Sgt. Gott (28 years of service with the USPP) 1940 Chevy G506 4112 cargo dump 1942 Diamond T G509 969A 4 ton wrecker 1942 Ward LaFrance G116 series 2 10 ton wrecker 1944 Ward LaFrance G116 series 5 10 ton wrecker 1931 Ford AA with a WEAVER crane 1944 Sterling HC 165 tractor 1944 Autocar U7144T w/ 10 ton trailer
| | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | My expierence with self-rebuild of brake parts on these old trucks, went terribly bad. I rebuilt some of the wheel cylinders and the MC myself. I wound up having to remove all those big wheels and tires, drums and axels twice. The MC and the WC's failed. I bought new wheel cyls and a new master cylinder. Now, no problems. I got them all at a reasonable price at NAPA and Rockauto. This was a 57 GMC 2 1/2 ton with 8 wheel cylinders.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Aug 2012 Posts: 28 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 28 | I too have had reasonably good luck with NAPA. I had to do most of the part number research myself but they wound up having access to new wheel cylinders both front & rear for my '46 2Ton. I can't attest to the master cylinder kits, though, as I was lucky enough not to need one.
Pete P. Harborcreek, Penna. | | | | | Joined: Apr 2014 Posts: 10 'Bolter | | 'Bolter Joined: Apr 2014 Posts: 10 | I didnt think it could be that easy. I will check with my NAPA store. Thanks for all the replies.
Chris
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Make certain that you inspect the cylinder bore for rust pitting before you spend money on a rebuild kit. Years of non-use tends to create a lot of condensation in the MC cinder wall. Pitting will result in leaks. | | | | | Joined: Aug 2005 Posts: 71 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 71 | HI ,Napa online can be a problem child ,Here is a trick for the Napa to find parts for your truck . 1 - put in search box master cylinder 2 - do not put any info to what kind of vehicle your looking for click search . 3- now it will be a new page showing master cylinders now look for medium to heavy duty trucks in the menu on the left ,then the make ,and then the year . Now you should see the master cylinder listed for your truck it should say one and a quarter inch bore same as my 48 2 ton Part Number: UP 33 $20.70 /ea rebuild kit only available wheel cyl. front Part Number: UP 3406 31.95 /ea kit Part Number: UP 8 $14.85 /ea Wheel Cylinder - Rear Part Number: UP 3677 102.60 /ea kit Part Number: UP 37 $15.75 /ea
RAYBESTOS Part # MC9220 master cyl rockauto.com $44 and change plus shipping DORMAN Part # M9220 master cyl. rockauto.com $80.79 rockauto.com has the the wheel cyl's much cheaper Just call me I can give you more info .865 274 3793 EST Florida .,I'm up late paul I changed mine to a one and a quarter inch bore dual circuit master cyl. a 7" dual diaphragm booster ,great brakes but it needs a vacuum holding tank and check valve put into the system . Hope this helps Paul N.
1948 Chevy 2 ton flatbed ex fire truck , and various motorcycles .
