9 members (TUTS 59, Millenimech, cmayna, Hanks custodian, Otto Skorzeny, Oswald, Cosmo, Bill Hanlon, gswbbc),
89
Mod | | | Forums66 Topics128,042 Posts1,055,522 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2003 Posts: 313 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 313 | Finally got my new bed wood, got it all fitted, sealed and sanded and ready to install. Looking for tips from those of you who have installed new bed wood before. It would seem to make sense to just loose fit all the nuts and bolts first, but give me some pointers so I don;t want to throw wrenchs across the street in frustration.  | | | | | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | You are on the right track. Get a friend to help and it will be even better. Just make sure you haven't mixed up the cross braces. | | | | | Joined: Feb 2004 Posts: 5 New Guy | | New Guy Joined: Feb 2004 Posts: 5 | One thing I learned the hard way was to treat the wood thoroughly with both oil and varnish before installing the bed pieces. I originally used what was advertised as a high quality outdoor urethane varnish, but it only lasted a year before it started to lift. I took the wood out again, stripped, sanded and then used three coats of Watco Danish wood oil. After drying and light sanding I applied three coats of marine spar varnish. The color, finish and durability is much better. | | | | | Joined: Feb 2004 Posts: 85 Member | | Member Joined: Feb 2004 Posts: 85 | Also, before your final tightening check the gaps on either side of the bed between the cab and make sure their kinda equal, not catty-wampus (I know thats hillbilly, not Hawaiian, but i love that word)I didn't on my '54 and that 1/4 round piece between the bed and running board got awful close to the cab on 1 side. Aloo-ha | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Originally posted by Kimo: catty-wampus hmn, and here I was thinking it was wampus kitty. 'shrug' -W | | |
