3 members (1955 1 Series, Gdads51, 1 invisible), 75 guests, and 2 robots.
Topics128,037
Posts1,055,582
#107207 02/14/2004 12:21 PM
Finally got my new bed wood, got it all fitted, sealed and sanded and ready to install. Looking for tips from those of you who have installed new bed wood before. It would seem to make sense to just loose fit all the nuts and bolts first, but give me some pointers so I don;t want to throw wrenchs across the street in frustration. grin
1936 GMC T-14 1/2-Ton Pickup
#107208 02/15/2004 1:31 AM
You are on the right track. Get a friend to help and it will be even better. Just make sure you haven't mixed up the cross braces.
1956 Chevy 3100
261/700r4 (formerly 3 speed OD)
More pix on Photobucket
#107209 02/16/2004 8:44 PM
One thing I learned the hard way was to treat the wood thoroughly with both oil and varnish before installing the bed pieces. I originally used what was advertised as a high quality outdoor urethane varnish, but it only lasted a year before it started to lift. I took the wood out again, stripped, sanded and then used three coats of Watco Danish wood oil. After drying and light sanding I applied three coats of marine spar varnish. The color, finish and durability is much better.
#107210 02/16/2004 10:05 PM
Also, before your final tightening check the gaps on either side of the bed between the cab and make sure their kinda equal, not catty-wampus (I know thats hillbilly, not Hawaiian, but i love that word)I didn't on my '54 and that 1/4 round piece between the bed and running board got awful close to the cab on 1 side. Aloo-ha
#107211 02/18/2004 11:27 AM
Socket Breaker
Socket Breaker
Quote
Originally posted by Kimo:
catty-wampus
hmn, and here I was thinking it was wampus kitty.
'shrug'
smile
-W
