5 members (Hush, Otto Skorzeny, 52Carl, 55shaker, JW51), 158 guests, and 2 robots.
Topics128,108
Posts1,056,238
Members48,437
#107197 11/20/2001 5:51 PM
I've been looking at MIG units and it seems that one of the big differences on the low priced units from big sellers, ie. Miller/Hobart and Lincoln is voltage control.
The lowest cost units have a 4 position "tapped" voltage control as opposed
to a "continuous" control. The tapped units appear to be about a $150 less money. I'm leaning to the continuous - got any opinions about this?
I plan to use this unit to learn with and intend to work with thin materials like sheet metal. Building heavy frames and trailers etc. is not my intention. I have a '85 F**d to practice on and then on to '51 Chevy.
#107198 11/21/2001 6:42 AM
My advice is to buy the best one you can afford, even if you have to save a little longer to get it. It's easier to weld with the better machines and you have more control. At our museum we had a 120 volt Lincoln for about a year before we decided to sell that one and get the 220 volt model. It's even better, and we weld steel up to 1/4" thick with no problem.
Fred
52 3600
69 C-10
#107199 11/21/2001 8:16 AM
Also, think about repair parts. You can get Miller / Lincoln parts at any weld shop. Can you do the same with the cheaper units? Joe
#107200 11/21/2001 11:55 PM
V
V Offline
I bought one of the cheap Lincoln Weld-Pak machines a couple of years ago. While it is a pretty good machine, I wish I would have sprung for a better one. I exceed the capability of the machine pretty regularly. I thought that I would just use it for sheetmetal, but I've used it for a lot more. It doesn't have the oats to do anything more than simple (upto 1/8 inch) work. I do a lot more fabrication than I thought I would. Don't scrimp.
#107201 11/22/2001 3:23 AM
I have had an "off brand" (Century, sold trough Snap On) for about 15 years and it has performed very well. I had to replace the gun twice, other than that nothing. It is a 220/205 amp.
At work I use a small 110 volt Miller 130. I HATED it at first, but after getting use to it, I now find that I enjoy using it. I weld frames (1/8") with out a problem.
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
#107202 11/22/2001 4:14 AM
SR
What was it that you hated about the Miller 130?
No one has mentioned the "tapped" control verses the "continuous" control? Doesn't make a difference?
PRW
#107203 11/22/2001 8:20 AM
Paul, the lack of control (four heat settings)and it just seemed to be tempermental. I still think it is, I have jsut gotten used to it and prepare the metal better and keep the nozzle clean.
My Century has 9 heat settings and it just seems that the 220 welder will burn through more contamination than the 110.
I had just left a shop with the best welder I had ever used and was more than a little spoiled. It was an AIRCO 220 running on three phase, the perfect power source for a MIG. The "Converter" in the welder that changes the AC to DC provides a much smoother flow of electricity to the tip, it would weld through just about anything! It would almost weld my its self! It was also a continuous control, and it worked great.
I recently passed a pretty strict welding test for ICAR and we used a little 110 Lincoln welder, I don't know the model number but it too worked great.
1948 Chevy Pickup
#107204 11/25/2001 5:38 AM
GO HOBART!!! I have put many spools of wire through a little Hobart handler over several years of use. It has been a really good, trouble free machine, and welds everything from thin sheet metal to 1/4" stuff equally well.....
#107205 11/25/2001 4:48 PM
This reminds me of a question I've had for awhile. I added the MIG kit to the WeldPak 100 and am using a CO2/argon mix. What should the gauge setting be? Wherever I have it set now (I'm not at the shop) works OK, but I was wondering if there is a general rule.
#107206 11/25/2001 7:37 PM
pknauth, the standard is 25-30 cfh (cubic feet per hour) if your guage reads PSI instead, set it at 3-4 PSI. If there is a breeze in the area, up it a little.
1948 Chevy Pickup
