Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
8 members (GMCJammer51, IHPWR, DJHobbit'46Chevy, Danielbolt, Dragsix, RBs36, 2 invisible), 556 guests, and 1 robot.
Topics126,780
Posts1,039,296
Members48,100
Most Online2,175
Jul 21st, 2025
#1071443 12/03/2014 9:46 PM
As I have posted previously, I have just acquired a 1948 Chevy 3100 truck. There is a key lock on the passenger door but not the driver's door. How then do you lock the truck when away?
Hi clhaney, this is a common question because it seems so goofy today. You can do a search on this site and find out all about it. But basically you lock the drivers door with the little inside lock then slide across the seat and exit the passenger side. I'm guessing most people do as I do and get out the drivers door, open the passenger door and lock the drivers door from the little inside lock, then lock the passenger door. Not a big deal once you get used to it.
Dennis
40 Chevy 1/2 ton
Lock the door from the inside and then slide over and get out the passenger door.
When I put my door handles back on I reversed them. I put the one with the key lock on the driverside. It's on a 58 GMC.Larry
58 gmc 100 with 350 sbc
On his 1948 the lock is in the door and not in the handle.
do as described above.
1. Lock drivers door with inside door handle.
2. Slide across the seat and exit through passenger door,then lock with key.
tim
1951 3100 Chevrolet
I appreciate your replies. I am not aware of any small lock on the inside of the driver's door. All I have is the two handles, door and window.
Push the door handle forward with the door closed. This is assuming the handle is properly installed, pointing down and slightly forward.
Thanks everybody!
They are correct! Lock the door from the inside and then slide over and get out the passenger door.
The idea was you parallel park along city streets and don't get out into traffic. Also, you could then unlock and open passenger door for your girl, then she reaches over and unlocks driver door.
Grew up driving Model A's and '40's trucks...you get used to it.
caC
Just move the handle in the opposite direction than you would to open the door. You should feel it move into the locked position.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
What cletis and rich said !!!
1951 3100 Chevrolet
This is not such a silly question,I only found out how to fully lock my '50 fairly recently.
I knew of the single passenger lock (obviously) but I would lock the drivers side,scootch over the seat then try and lock the passenger door with the internal handle before I shut the door,then try to lock it with the external keyed lock......DUH!
Needless to say this didn't work so I just left it unlocked on many occasions...
I've only had the truck 11 years...... blush
More pix on Flickr.
I have a 1x1 oak stick that I keep on the floorboard. I reach in with it from the passenger side and give the driver's side handle a whack to lock it. I then lock the passenger side with the key.
Sometimes it's a pain to slide over if you have a bunch of stuff on the seat or pass. side floorboard.
33 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
Not what OP asked but I guess this goes back to a time when you were supposed to exit the vehicle on the passenger side (At least it was a law here). I know two folks who failed their Road test because they forgot to wait for the instructor to get out first.
I just put a lock in the drivers door.
Evan
Yeah, I had to ask the same thing. I thought someone had switched handles on my 57 Bigbolt.
But to stay correct, leave the key lock on the passenger side and slide across the seat. However this is a task in my LCF. The gearshift and park brake handle is in the way, when you are 70 and weigh 185 lbs.
Also try sitting under that big steering wheel, and the seat is all way back.
Folks must have been smaller back in them thar days.
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
The bigguns rode in the bed. smile
Carl
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.222s Queries: 14 (0.074s) Memory: 0.6742 MB (Peak: 0.7898 MB) Data Comp: Zlib Server Time: 2025-09-22 20:48:25 UTC
Valid HTML 5 and Valid CSS
