| | | Forums66 Topics128,154 Posts1,056,857 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2014 Posts: 63 | As I have posted previously, I have just acquired a 1948 Chevy 3100 truck. There is a key lock on the passenger door but not the driver's door. How then do you lock the truck when away? | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Hi clhaney, this is a common question because it seems so goofy today. You can do a search on this site and find out all about it. But basically you lock the drivers door with the little inside lock then slide across the seat and exit the passenger side. I'm guessing most people do as I do and get out the drivers door, open the passenger door and lock the drivers door from the little inside lock, then lock the passenger door. Not a big deal once you get used to it.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Lock the door from the inside and then slide over and get out the passenger door. | | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | When I put my door handles back on I reversed them. I put the one with the key lock on the driverside. It's on a 58 GMC.Larry
58 gmc 100 with 350 sbc
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | On his 1948 the lock is in the door and not in the handle. do as described above. 1. Lock drivers door with inside door handle. 2. Slide across the seat and exit through passenger door,then lock with key.
tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Nov 2014 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2014 Posts: 63 | I appreciate your replies. I am not aware of any small lock on the inside of the driver's door. All I have is the two handles, door and window. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Push the door handle forward with the door closed. This is assuming the handle is properly installed, pointing down and slightly forward. | | | | | Joined: Nov 2014 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2014 Posts: 63 | | | | | | Joined: Nov 2014 Posts: 18 New Guy | | New Guy Joined: Nov 2014 Posts: 18 | They are correct! Lock the door from the inside and then slide over and get out the passenger door.
The idea was you parallel park along city streets and don't get out into traffic. Also, you could then unlock and open passenger door for your girl, then she reaches over and unlocks driver door.
Grew up driving Model A's and '40's trucks...you get used to it. | | | | | Joined: Jul 2004 Posts: 2,990 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,990 | I appreciate your replies. I am not aware of any small lock on the inside of the driver's door. All I have is the two handles, door and window. Just move the handle in the opposite direction than you would to open the door. You should feel it move into the locked position. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | What cletis and rich said !!! 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | This is not such a silly question,I only found out how to fully lock my '50 fairly recently. I knew of the single passenger lock (obviously) but I would lock the drivers side,scootch over the seat then try and lock the passenger door with the internal handle before I shut the door, then try to lock it with the external keyed lock......DUH! Needless to say this didn't work so I just left it unlocked on many occasions... I've only had the truck 11 years......  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | I have a 1x1 oak stick that I keep on the floorboard. I reach in with it from the passenger side and give the driver's side handle a whack to lock it. I then lock the passenger side with the key.
Sometimes it's a pain to slide over if you have a bunch of stuff on the seat or pass. side floorboard. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Oct 2013 Posts: 219 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 219 | Not what OP asked but I guess this goes back to a time when you were supposed to exit the vehicle on the passenger side (At least it was a law here). I know two folks who failed their Road test because they forgot to wait for the instructor to get out first. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I just put a lock in the drivers door.
Evan
| | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | Yeah, I had to ask the same thing. I thought someone had switched handles on my 57 Bigbolt. But to stay correct, leave the key lock on the passenger side and slide across the seat. However this is a task in my LCF. The gearshift and park brake handle is in the way, when you are 70 and weigh 185 lbs. Also try sitting under that big steering wheel, and the seat is all way back. Folks must have been smaller back in them thar days.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | Also try sitting under that big steering wheel, and the seat is all way back. Folks must have been smaller back in them thar days. The bigguns rode in the bed.  Carl
