| | | Forums66 Topics128,048 Posts1,055,541 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 28 New Guy | | New Guy Joined: Dec 2014 Posts: 28 | I have a 235 6 with rodchester 1bbl engine is freshly rebuilt new plugs ,wires ,points condenser, cap, etc. Valves adjusted with engine at operating temp at 6 and 16. Timing is set correctly, compression 150 or close on all cyls vacuum steady at 18.
It idles perfect problem is it will not run at speed > 1400 or so RPM. It sputters and backfires when you push it. It will get RPMs up if I pump the throttle otherwise just sputters. Just put a rebuild kit in carb and float adjusted to specs..
Any ideas?? | | | | | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | Timing? Advance not working? | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Fuel pump not putting out enough volume? | | | | | Joined: Dec 2014 Posts: 28 New Guy | | New Guy Joined: Dec 2014 Posts: 28 | Perhaps! How much movement is there supposed to be with the vacuum advance? The fuel pump is new.
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | Sounds like a problem w/the carbs accelerator circuit. 1st check is to make sure the short linkage that connects the plunger to the throttle lever is connected. Thats a very small clip that holds it on and they can pop off after a fresh rebuild (BTDT) | | | | | Joined: Dec 2014 Posts: 28 New Guy | | New Guy Joined: Dec 2014 Posts: 28 | Naw accelerater circit is attached and I can observe it spraying fuel. | | | | | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | I can't remember if the Model B has a power valve or not. If it does, that could be the problem. But if you carefully followed all the rebuild instructions, the carb is probably not the problem. | | | | | Joined: Dec 2014 Posts: 28 New Guy | | New Guy Joined: Dec 2014 Posts: 28 | Yes has power valve but I think Everything was put back correctly. | | | | | Joined: Sep 2013 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2013 Posts: 26 | Had a similar problem years ago. Turned out the new points I installed had very weak spring tension. The engine would idle perfectly but as soon as I accelerated points would " float " causing performance like you describe. | | | | | Joined: Dec 2014 Posts: 28 New Guy | | New Guy Joined: Dec 2014 Posts: 28 | Definitely the vacuum advance not functioning part is ordered.
Thanks for your help. | | | | | Joined: Dec 2014 Posts: 28 New Guy | | New Guy Joined: Dec 2014 Posts: 28 | Replaced the vacuum advance and it was a little better but still wont run at RPM. Sent the carb in and we will see what happens when it get back. | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Are you sure you don't have a couple of plug wires crossed? (CW 1,5,3,6,2,4). Hope this helps. HAPPY HOLIDAYS!
| | | | | Joined: Mar 2013 Posts: 186 'Bolter | | 'Bolter Joined: Mar 2013 Posts: 186 | | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I think that you need to make sure that the points you installed have both of the straps/springs installed. As mentioned before with only one spring the points bounce and it won't run other than at idle. | | | | | Joined: Aug 2004 Posts: 1,417 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,417 | Great job guys, another problem solved!
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Dec 2014 Posts: 72 Shop Shark | | Shop Shark Joined: Dec 2014 Posts: 72 | I used to have a sputtering issue with my 292 and it ended up being a vacuum leak in the carb...would idle fine, but when you'd hammer on it, it would sputter and sometimes die. | | | | | Joined: Dec 2014 Posts: 28 New Guy | | New Guy Joined: Dec 2014 Posts: 28 | Put the new carburetor on it still runs poorly at RPM misses badly. Any other ideas would be welcome ??? | | | | | Joined: Dec 2014 Posts: 72 Shop Shark | | Shop Shark Joined: Dec 2014 Posts: 72 | Have you checked your compression? Also sometimes if the timing is set wrong it can cause issues like that. Also check you intake ports for vacuum leaks...while the engine is idling cold spray some carb cleaner in the intake ports( DON'T spray it on the exhaust ports) and if the engine stalls...vacuum leak. Hope you figure out the problem soon. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Some points sets come with a removable strap/spring. If this is left of the points will float when the RPM's are increased.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2014 Posts: 28 New Guy | | New Guy Joined: Dec 2014 Posts: 28 | Compression 150 or close in all 6 . Vacuum 18 with no fluctuation guess I will re check all the timing stuff. Points look OK. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Are you sure the vacuum stays at 18(which is a little low)at higher RPM's? You may have a plugged exhaust system. Those mice can be tricky. I would also be sure the dwell stays steady with RPM's, I'm still not ruling that out.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | I remember an incident from many years ago, where I took a dune buggy with a turbo charged Corvair engine to the sand drags. Got smoked by a mildly rodded VW. My buggy ran great setting at the line but when I showered down on the accelerator peddle it developed a bad miss and had no power. Got back to the pits and pulled out my dwell meter and found the points had somehow closed up. Readjusted them using the dwell meter and it ran great the rest of the day. Just a thought!
| | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | as the points close up, for every degree of dwell increase, the crankshaft timing is retarded two degrees. Jerry
| | | | | Joined: Dec 2014 Posts: 28 New Guy | | New Guy Joined: Dec 2014 Posts: 28 | Turns out that it was a weak spring on the points. It runs absolutely perfect now. Damage done? Lost the patina on the carb! Sure fun finding the problem though.
Thanks for your all's help.
Will try and post pic later on when it looks a little better. | | | | | Joined: Aug 2013 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 255 | | | | | | Joined: Dec 2014 Posts: 28 New Guy | | New Guy Joined: Dec 2014 Posts: 28 | | | | | | Joined: Dec 2014 Posts: 28 New Guy | | New Guy Joined: Dec 2014 Posts: 28 | Oh! Forgot to post answer to problem. The point tension was not stiff enough replaced points again and it ran great. | | |
