| | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 18 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 18 | Almost ready to put the cab back on the frame. Any suggestions or useful links you can point me to? (1955 Series 1) | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 2 rear side shackles and 2 front floor bolts.
We laid the cab on the frame and put the floor bolts in place.
Lift each side to bolt-on the shackles.
I dimly recall that there is little or no side-to-side or front-to-back adjustments.
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | As Tim said, either it's mounted or it isn't. A bit of slack in the front holes and the shackle rears can be shimmed with shims between the bracket and the frame but this is about it 0n adjustment. On any car/truck of any year we use 12" to 15" long all thread rods in the mount holes so the body can be guided into place from long distance rather than set onto the frame and then wrestled around.
Evan
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Evan, that is a darn good idea, thanks. Steve 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
