10 members (chevy51truck, Peggy M, Gdads51, KEVINSKI, Wickedbass, Tinker5, Hotrod Lincoln, Woodcmiami, 3800GUY, Bill Hanlon), 123 guests, and 2 robots.
Topics128,036
Posts1,055,458
Members48,422
#1070467 11/27/2014 6:36 PM
Almost ready to put the cab back on the frame. Any suggestions or useful links you can point me to? (1955 Series 1)
JTS2530 #1070489 11/27/2014 11:08 PM
2 rear side shackles and 2 front floor bolts.
We laid the cab on the frame and put the floor bolts in place.
Lift each side to bolt-on the shackles.
I dimly recall that there is little or no side-to-side or front-to-back adjustments.
JTS2530 #1070492 11/27/2014 11:34 PM
As Tim said, either it's mounted or it isn't. A bit of slack in the front holes and the shackle rears can be shimmed with shims between the bracket and the frame but this is about it 0n adjustment. On any car/truck of any year we use 12" to 15" long all thread rods in the mount holes so the body can be guided into place from long distance rather than set onto the frame and then wrestled around.
Evan
JTS2530 #1070498 11/28/2014 1:13 AM
Evan, that is a darn good idea, thanks.
Steve
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
