5 members (Phak1, Gray_Ghost, NJC, Otto Skorzeny, UtahYork), 102 guests, and 1 robot.
Topics128,057
Posts1,055,810
#106996 02/18/2005 8:13 PM
Does anyone out there have recent experience
with bed wood sets (original pine) purchased
from a vendor? Sounds like an easy way
to get the replacement, but I want to make
sure the quality is ok.
#106997 02/18/2005 9:44 PM
PM53: Got my boards and hardware from Bruce Horkey Cabinetry. Well pleased with the product. Ben popcorn The Truth is Out There (Good luck)
#106998 02/18/2005 9:54 PM
I didn't mention the truck - 53 AD, so
8 boards in the bed.
#106999 02/19/2005 4:31 AM
my brother got oak :mad: for his 64 thay s**k bad warped and cracked and will not hold a finish .
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
#107000 02/19/2005 4:42 AM
I
I Offline
I think if someone sent me bad wood I would send it back.
Make it yourself if you are so inclined I have seen online the measurements and tools necessary to do it.
Cut some boards, router the edges, drill a hole or 24, and Viola!
Don't you know who I think I am?
I've been thinkin' about freaking out. If I could just find the time.
http://community.webshots.com/user/ifrizlfri
#107001 02/19/2005 6:03 AM
http://community.webshots.com/photo/189861216/190641020casZtj
This is a picture of my bed I finished from
Mar-K. I used pine and put a ebony finish on it. I was real happy with there quality and service. They sent one board that was not drilled right and they sent another right out. I can't say enough good things about my experience dealing with them. Cecil.....
#107002 02/19/2005 1:33 PM
I also bought a pine bed kit with stainless strips and hardware from MAR-K in Oklahoma. The quality, fit, etc. was very good and they are nice to deal with. I did think their shipping was a bit slow though.
Don
#107003 02/19/2005 2:08 PM
PM53,
The pine boards that I bought from Chevy Duty (drilled and grooved) were excellent. Bruce Horkey has an excellent reputation.
51Jimmy's finish sounds like what I did - several coats of ebony stain and then several coats of thinned marine spar varnish (satin finish was my prefererence). The boards needed to be sanded before finishing - they still had minor planing marks.
Tim
#107004 02/19/2005 3:21 PM
I used a kit from Mar-K, free shipping if you order online. Great quality, fit right, looks great. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#107005 02/21/2005 12:27 AM
i bought my entire bed including the pine wood from Mar-K. No complaints here. Very nice product.
Tim Sheridan
1947 First Series Chevy 1/2-Ton
"Liberty Series" - "Art Deco" - Whatever you'd like to call it.
#107006 02/21/2005 2:38 AM
Mar K is the vendor to go with, all the other vendors use them as well. I used oak on my truck, but they have pine and the kits are the best. Mine practicaly put itself in.
1936 GMC T-14 1/2-Ton Pickup
#107007 02/22/2005 5:12 AM
You may want to use a cabinet scraper instead of a sander for bed wood to remove the tool marks. The reason being that the scraper cuts the grain but the sandpaper kind of frays it. The stain will take much better, especially in the case of oak which has a more open pore structure (which should be filled before staining). The wood will also be slightly more resistant to rot and dings.
A cabinet scraper basically a flat piece of spring steel with an edge that has a burr burnished onto it. You can get wood to a finish flat surface in just a few strokes.
Paint & Body Shop moderator
#107008 02/25/2005 5:06 AM
Junior Member
Junior Member
I had my bed wood made by a local cabinet maker. I found the demensions online. I didn't want the holes for the bolts in the planks so that was a reason why I went that way. I got finished hardwood for the same price as pine if I had fo ordered from a dealer. You'd be suprised what you can find if you ask around. The carpenter told me it took him about an hour or so to set up and after that making the boards was quite straight forward.
