1 members (Steve_H),
186
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,934 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Gentlemen,
I am in the process of making some anchor brackets to hold the seatbelts for my 41. It has been a long time since I have had a vehicle with lap belts and a bench seat.
Before I start welding, I have a couple of questions: 1) Aesthetically, where should the female end (fixed length side)of the seatbelt lay when extended out on the seat? This is when the vehicle is being shown not when the seatbelts are being used.
2) Are there any attributes as to where the buckle and latch should rest when being worn (ie is there any ergonomic advantages to have the hardware placed at your bellybutton or off to the side)? The 3 point belts on all of my more modern vehicles have the female end very close to the corner where the seat bottom and back meet.
Thanks in advance,
Paul
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Wrench Fetcher, PhD | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Anyone??? Need some opinions, there is no wrong answer. | | | | | Joined: Sep 2010 Posts: 1,715 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,715 | The 3 point belts meet near the seat because they are 3 point belts.
It doesn't matter on 2 point belts where the buckle is. There is no wrong placement. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Jun 2007 Posts: 134 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 134 | They way mine ended up was with about 6" to 7" of the female end past the seat. Allows me to get a hold of it to put the shoulder belt in when I buckle up. If it was further towards the center of the body I'm not sure the shoulder strap would sit right. | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | I have the basic lap belts. I installed the fixed ends (end with the tip that plugs into the buckle) on the outside and the buckle ends on the inside. I don't show my truck so I am unaware of any seat belt protocol but since mine is a driver I put those rewinders on the outside fixed ends so they retract out of the way when they are unhooked. I let the buckle ends lay straight out towards the dash on the seat. Good luck Dave | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Gentlemen,
Thanks for the input. It makes good sense that the female end of the belt is near the corner of the seat bottom and back on a shoulder belt arrangement, never really thought of it much, but makes good sense...thanks. Dave I think my set up will be very much like yours but in a Deco. Did you mount the belts near the cab floor, including the retracting side? It looks like I will need to fabricate a bracket to elevate the retractor end so the male end of the belt doesn't get lost behind the seat.
Thanks again,
Paul | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Perhaps these sites will help anyone thinking about installing seat belts. Seat Belt Installation Shoulder Harness Mounting Plate Harold
Harold Is a restoration ever finished? | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Thanks Harold, even though I am installing lap belts only, those links do help. Did you install seat belts in your 46? | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Paul, did you see the PM (private message) I sent you last week?
Brad Wrench Fetcher, PhD | | |
