1 members (Otto Skorzeny),
90
Mod | | | Forums66 Topics128,090 Posts1,056,380 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2013 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2013 Posts: 38 | Took the old glass and its frame out, Painted the frame, installed new window channel and now cant get glass back in- Same glass. Same Frame. New Channel. Once the glass is into the door it will not tilt the degrees to get it to fit the channel. Looked aat the Tech Tips and it shows how to get glass out, but not back in. Am I missing something. HELP. ken
Oh, she is a 1948 Delux PU the one whthout he vent windows. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Them big old 1 piece windows just, and I mean just fit into the door. I have left the window regulator unbolted to give a little bit more room. The channel that is in the door is wider for the 1 piece window. I would try fitting it on the glass before installing it into the door frame. If the glass with the trim won't fit on the bench It won't fit when it is in the door either.
Steve H
