2 members (baldeagle, 1 invisible),
122
Mod | | | Forums66 Topics128,095 Posts1,056,468 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2013 Posts: 11 New Guy | | New Guy Joined: Sep 2013 Posts: 11 | I ordered two mirror arms and mirrors for my 46 1/2ton. I see how they should go on but it is not working. Jim Carter people told me to screw them to the door. There is a flange with a threaded hole on them but they line up with the cab. Any one know how these go on correctly? | | | | | Joined: Oct 2012 Posts: 182 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 182 | They do not screw onto the door. They screw onto the side of the door hinge that is bolted to the cab. There is a countersunk hole in the hinge to accept a flat head machine screw. | | | | | Joined: Sep 2013 Posts: 11 New Guy | | New Guy Joined: Sep 2013 Posts: 11 | Thanks Sput, makes more sense now, but I am not seeing the counter sunk hole. Any chance you could please send a pic or two? | | | | | Joined: Oct 2012 Posts: 182 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 182 | My trucks are parked elsewhere, so I can't get a picture. Here is a picture front the internet that shows the countersunk hole on the lower left hinge piece. Click | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Mine don't screw or bolt to anything. Is this what you have?All you have to do is take the hinge pin out, put the mirror arm in, and put a new longer hinge pin back in. The threaded hole could be used to secure it to the hinge, but I found that unnecessary. I had to grind the little tab slight as it was too thick but otherwise it worked great. | | | | | Joined: Sep 2013 Posts: 11 New Guy | | New Guy Joined: Sep 2013 Posts: 11 | Thanks, that helps a lot! | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | There is a screw on it to adjust and hold in a specific area Dan | | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | This is something I am needing to do to. I can see the hole on my hinges but the cab sheet metal is in the way. If one decides to use that small screw hole, it looks like you have to remove the entire hinge just to put the bracket on. By the time I got them off, one may as well replace them with new hinges! Or am I missing something? | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Having installed it without the screw and driven it over 5000 miles that way with no mirror vibration or problems I don't think it's necessary to put a screw in. | | | | | Joined: Apr 2013 Posts: 119 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 119 | Tricky part is getting pin out (usually requires heat) without damaging surrounding finish (not a problem with rat rods)
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | To remove the pins on my 38 Master, which is similar, I used the ball joint/u-joint press. It is fashioned like a very large u clamp. I used a small bolt to push on the bottom of the pin and a socket over the head of the pin that rests on the hinge body. It really screeched when it started to move but it caused no damage. | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Tricky part is getting pin out (usually requires heat) without damaging surrounding finish (not a problem with rat rods) PB blaster a couple days in a row and then a small hammer and drift pin is all that is needed.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | To remove the pin I heated it carefully with a handheld propane torch and then used a hammer and punch. | | |
